Tyer pressure help - Kawasaki ZX-10R.net
post #1 of 4 Old 05-10-2014, 08:03 AM Thread Starter
Tyer pressure help
I have a gen 4 running dunlop sportmax d212 gp pro 4 s
Not sure wat pressures to run
Am just street use and am in the uk so its no as hot as
Accross there
skooshy is offline
post #2 of 4 Old 05-10-2014, 09:25 AM
Crash Test Dummy
Hernando's Avatar
Send a message via Yahoo to Hernando Send a message via Skype™ to Hernando
24 psi in the rear or 1.7 bar hot or 18-20psi 1.3 bar cold
33 psi front or 2.3-2.4 bar hot or 2.1 bar 30 psi cold
Bear Jew
Hernando is offline
post #3 of 4 Old 05-10-2014, 01:30 PM
Caffeine's Avatar
Just looked up the tire sounds impressive..
http://www.visordown.com/product-fea...iew/22863.html
"When it comes to pressures, the NTEC technology allows you to run alarmingly low pressures: I was running 30psi hot on the front and 22.5psi hot on the rear.
Caffeine is offline
post #4 of 4 Old 05-10-2014, 06:43 PM
Crash Test Dummy
Hernando's Avatar
I don't know if they make the best street tire though
Bear Jew
Hernando is offline
Tire Pressure Bond The ZX-10R 12 06-21-2010 03:44 PM
Tire Pressure fallfornoone Performance and Tech 1 05-16-2008 03:28 PM
Tire Pressure S6X ZX-6R & ZX-6RR Archives 7 09-13-2007 02:00 PM
Under Pressure!! BenRyDn The ZX-10R 11 04-07-2005 06:59 AM
Canít take the pressure. evander The ZX-10R 10 08-21-2004 05:05 PM
