Tire wear question, Pros needed. - Kawasaki ZX-10R.net
post #1 of 35 Old 05-17-2012, 12:31 AM Thread Starter
All show and all go 10r
JLG0987's Avatar
Ok so I have 2 bikes to compare. I will break it down. The ZX10R is in question.
08 ZX10R
Ohlins R&T forks
Ohlins TTX shock
Stock geometry I believe
Tires
Pirrelli Supercorsa sps.
Suspension is sprung for my weight but not setup. Just how it came setup for me. Stiff rear shock fairly soft forks. Bike feels great holds a line and is very neutral.
05 ZX6R
fork bodies are stock with ohlins piston kit, revalve, sprung for my weight, etc...
Shock is stock as it was good for me.
The suspension is setup for me with proper sag. Stock geometry.
Tires
Michelin power pures.
My question is in regards to the supercorsa wear (chicken strips). The size difference is massive(front and rear) compared to my 6R. is this because of the suspension difference or do the supercorsas deform completely different. The 10R currently feels really good in the corners with tons of feedback and feels super planted. The 6R at its current state near the limit show feels like it wants to fall over into the corner.
10R
Front
Rear
6R
Front
Rear
This is from street riding
JLG0987 is offline
post #2 of 35 Old 05-17-2012, 12:50 AM
R/T Performance's Avatar
6r rear is a 180?
10r rear is 190?
Same size fronts?
is so theres our answer if you get to the edge of the front the rear will be past it's grip range
2010 Zx10r Black spark Bazzaz zfi with QS,Puig Blue Double bubble,vortex rear sets,Blue Spools, fork sliders and oil fill cap,M4 street slayer,Penske triple clicker -1 +3 gearing 520 chain
R/T Performance is offline
post #3 of 35 Old 05-17-2012, 01:00 AM Thread Starter
JLG0987's Avatar
Fronts are the same size 6R is a 180/55 rear, 10R is a 190/55 rear
JLG0987 is offline
post #4 of 35 Old 05-17-2012, 01:01 AM Thread Starter
JLG0987's Avatar
so the rear tire of the 10R will deform to properly to match the front tire?
JLG0987 is offline
post #5 of 35 Old 05-17-2012, 01:18 AM
barnes's Avatar
Send a message via MSN to barnes
Nothing to do with tyre sizes...
Can still run a 190 rear to the edge with matching front.
Its the profile of the 2 different brand tyres...Michelins are a fatter profile tyre than the Pirrelli even though the numbers are the same.
Pirelli's have a very steep shoulder compared the the Michelins.
Design by a genius, Built by a craftsman, Ridden by a twat....
“See God. Then back off” Kevin Schwantz on his late braking technique.
barnes is offline
post #6 of 35 Old 05-17-2012, 01:21 AM Thread Starter
JLG0987's Avatar
I'm not comparing the 2 brands just front and rear comparisons for wear. I just seems like the 6R tires are work better together to compared to the 10R. But that's based on looks not feel. The 10R feels 10x better.
JLG0987 is offline
post #7 of 35 Old 05-17-2012, 01:35 AM
barnes's Avatar
Your comparing chicken strips and the reason is the tyre profiles...and the Pirellis SC2 grip much better than the Michelins hence the better feel.
I can still read 2CT on the Michelins so u got heaps before u push there limit...
As a test put the Pirelli 190 rear on the 6R and leave Michelin front i bet you will end up with zero chicken strips on the front of the Michelin.
barnes is offline
post #8 of 35 Old 05-17-2012, 01:55 AM Thread Starter
JLG0987's Avatar
there supercorsa sp not sc2.
JLG0987 is offline
post #9 of 35 Old 05-17-2012, 03:56 AM
The Pirellis are a different profile, very 'rounded', that's all. Also, the rears deform a lot more and will grip even when you appear run out of 'edge' ... whereas the front won't, so they need to be different.
Remember how I said in another thread that you should be careful of not having too low a pressure in the front? This is the reason.
ZedextenR. is offline
post #10 of 35 Old 05-17-2012, 03:59 AM
barnes's Avatar
Same diff...
Same as the above post...
barnes is offline
Gen 1: Another Noob Question for the ZX10r PROS! Bpcullen General Motorcycle Discussions 3 03-22-2012 03:45 AM
stock bto16 tire wear question? Mattercyclist The ZX-10R 13 07-28-2010 08:58 PM
Still don't get the tire wear... 26606 General Motorcycle Discussions 22 10-15-2009 10:12 PM
photoshop pros needed dabeast664 The Out House 2 12-25-2007 12:47 AM
Tire wear Chrispy Performance and Tech 13 09-08-2006 05:22 PM
