Tire wear - Kawasaki ZX-10R.net
post #1 of 10 Old 08-10-2012, 10:33 AM Thread Starter
Tire wear
Got a few pis of my tires,any hint as to why they look like they do?Click image for larger version
bikeserv is offline
post #2 of 10 Old 08-10-2012, 11:51 AM
SkyDork's Avatar
Looks pretty normal to me for a tire that is ridden pretty hard.
#WordCrimes
SkyDork is offline
post #3 of 10 Old 08-10-2012, 12:22 PM
Slo
Is still Slo
Slo's Avatar
Originally Posted by skydork View Post
looks pretty normal to me for a tire that is ridden pretty hard.
+1
2015 ZX10R - Archer flash+goodies - Arrow - TechSpec lock kit tank pad - Spiegler lines
CL Pads - 520 kit - LSL sliders & rearset - Yoshi case guards - custom seats - Gyrocam GoPro 4 Silver
Slo is offline
post #4 of 10 Old 08-10-2012, 01:07 PM
Fred-R's Avatar
It's a pretty nice wear you got there... went to the track ?
Fred-R is offline
post #5 of 10 Old 08-10-2012, 05:09 PM Thread Starter
Yeah i m tracking the bike and i m slowly converting it to a race bike.The front tire is making some marks as if its not loading as it should and runs wide a bit while i m powering out of turns.i m not trailining the brakes on entry hence my worry for the front.the bike is lifted 10mm at the rear and lowered 5 mm at the front.anyone knows what is the limit in lowering the front with a high rear?or should start trial and error(gulp)
bikeserv is offline
post #6 of 10 Old 08-10-2012, 05:58 PM
Fred-R's Avatar
the mark you see on the front tire is cause by the front end skidding on entry or at the exit. the main thing I can see when you say that the bike run wide is that the rear squat when you're in the gas, that could explain why the front unload and skid. you will find when you'll get quicker that sag is useless. Swing arm angle is the key to bike stability on exit and you should match the front to handle well...
hope this helps
Fred-R is offline
post #7 of 10 Old 08-10-2012, 09:56 PM Thread Starter
That sounds logical.So,i ll try with a bit more comp and take it from there.The way i see it it ll be either more compression,lower front,and maybe mess a bit with the antisquat using different sets of sprockets.Sounds about right?
If nothing cures it,then i ll have to start looking at a different solution,in damping and such.Will let you know how it goes
bikeserv is offline
post #8 of 10 Old 08-12-2012, 01:46 PM Thread Starter
Well,tried to mess with the rear comp and it made no difference to the front tire,and the bike was a bit worse in the bumpy sections of the track,and more prone to wheelie out of turns.next step i ll lower the yokes another 2mm and hope it wont start sliding.will see
bikeserv is offline
post #9 of 10 Old 08-12-2012, 03:25 PM
Fred-R's Avatar
squat can result in to much rebound damping..... It's called packing
I gained 2 sec per lap with 2 clicks out of rebound last trackday
you can try it....
Fred-R is offline
post #10 of 10 Old 08-13-2012, 12:39 AM Thread Starter
you can try it....
Next trackday is the coming weekend.I ll try that too,got a notebook and write down all the changes and the effect i feel they got.Will try the rebound and see.Though last time i noticed that i m letting my body slide on the rear of the seat when i accelerate,so that might be contributing to it.When i m sitting further to the rear i get a better feeling from the rear sliding,but i could also get more weight off the front than i should.Dont know if that makes any sense,but should try it also.Every trackday is a test
Btw thanx Fred
bikeserv is offline
Still don't get the tire wear... 26606 General Motorcycle Discussions 22 10-15-2009 10:12 PM
odd Tire Wear..... Fixer The ZX-10R 20 06-23-2009 06:38 PM
tire wear pattern, wtf is this 10roller Performance and Tech 44 06-15-2009 06:39 PM
Tire wear Chrispy Performance and Tech 13 09-08-2006 05:22 PM
Rear Tire Wear zx10x2 The ZX-10R 14 03-29-2006 07:58 PM
