tire rub - Kawasaki ZX-10R.net
post #1 of 11 Old 08-06-2012, 09:29 AM Thread Starter
motomike's Avatar
tire rub
i'm getting a slight tire rub on my 2nd generation rear tire.i've run a 190/50/17 and a 190/55/17 michelin pilot power 2ct.the rub is in the center of the tire-not much/very little. any ideas ?
lead,follow or get out of the way !
motomike is offline
post #2 of 11 Old 08-06-2012, 09:46 AM
SkyDork's Avatar
WTF? The 190/55 is the standard size for that bike. There should be no rubbing issues at all. Where is it hitting the bike? Swingarm, hugger, etc.? What's your gearing? Too big of a rear sprocket would move the axle far forward. Still shouldn't hit anything though.
Need more info on your setup and pics would be handy.
#WordCrimes
SkyDork is offline
post #3 of 11 Old 08-06-2012, 09:52 AM Thread Starter
motomike's Avatar
stock rear sprocket/-1 on front-a slight scrape on the center of the tire.my brother has the same problem.he went down to a 190/50.
motomike is offline
post #4 of 11 Old 08-06-2012, 09:53 AM Thread Starter
motomike's Avatar
it only does it at 150 + mph
motomike is offline
post #5 of 11 Old 08-06-2012, 09:54 AM
Is it rubbing on the bike? If so where? Or can you only find the "rub" mark on the tyre?
PS. Could it be your plate/tag? I see a lot of people over hear mount them under their seats, a lot closer to the rear wheel.
trebor27 is online now
post #6 of 11 Old 08-06-2012, 09:56 AM Thread Starter
motomike's Avatar
can only find the mark on the tire.took the hugger off-no marks on it.
motomike is offline
post #7 of 11 Old 08-06-2012, 10:00 AM Thread Starter
motomike's Avatar
my tag is not that close,under the tail light. i guess i'm going to get my brother to follow me at 150-just to see.
motomike is offline
post #8 of 11 Old 08-06-2012, 10:17 AM
SkyDork's Avatar
150mph? Well, no shit then. It's tire growth from the sustained high speeds. The tire deforms under that much force. What tire pressure are you running?
#WordCrimes
SkyDork is offline
post #9 of 11 Old 08-06-2012, 11:10 AM Thread Starter
motomike's Avatar
lol.it only has done it on the last 2 tires.i'm runn;n around 36-38
motomike is offline
post #10 of 11 Old 08-06-2012, 11:14 AM
SkyDork's Avatar
Well, that's pretty high pressure and maybe not the issue then. It will grow taller at the high speeds, but not much with that high a pressure. I'd pull the hugger off and start measuring the clearances between the swingarm and the tire.
#WordCrimes
SkyDork is offline
Tire Warms Vs Tire socks Gang Green Performance and Tech 3 06-21-2008 11:02 AM
Tire Review: Dunlop N-Tec DOT rear race tire wsmc27 Track 4 08-09-2007 03:14 PM
Would you feel safer on a Z(W) tire or a Z(Y) tire? Grease The ZX-10R 15 04-30-2007 01:10 PM
Monting rear tire without tire machine? blackisfaster Performance and Tech 9 04-24-2007 01:28 PM
