tire question - Kawasaki ZX-10R.net
post #1 of 14 Old 06-29-2012, 01:29 PM Thread Starter
2k3gixxer1000's Avatar
tire question
so guys, after a day of playing with my rear shock... i cant seem to sort out this issue...
anyone have an idea on what is causing this??
btw this was a fresh tire at the start of the day, pirelli sc3 supercorsa
2k3gixxer1000 is offline
post #2 of 14 Old 06-29-2012, 01:59 PM
Brian24's Avatar
My tire looked pretty close to that when I did my first track day. I had too much air in the tire and my rebound was off. How much air are you running? Alot of the time there will be suspension guys at the track, did you check with them?
Sent from my SGH-T989
Brian24 is offline
post #3 of 14 Old 06-29-2012, 02:01 PM
kman0066's Avatar
Tire pressure wrong or too much rebound dampening would be what I look at first if my tire looked like that. Running tire warmers? It's also incredibly hot out there now, so maybe not the right tire compound for the conditions.
kman0066 is offline
post #4 of 14 Old 06-29-2012, 02:13 PM
MR ZX_R DC's Avatar
Nice rims.
MR ZX_R DC is offline
post #5 of 14 Old 06-29-2012, 02:54 PM
dmj120's Avatar
Work's firewall blocks the pic. Is there cupping or scalloping on the stipes? Try reading http://feelthetrack.com/?page_id=90
-Josh
Just a Playa In Management Position
dmj120 is offline
post #6 of 14 Old 06-29-2012, 04:15 PM
BusaCaptain's Avatar
Looks like low tire pressure. Should be around 28 hot off the track. I run 26 hot with slicks and 27 with Q2's.
2008 Hayabusa-Yosh Full Race Exhaust can cut 5", PCV w/Autotune, BMC Filter, Cruise Control, HID's. Last Dyno Run 183 Rwhp/107 Ftlbs at 48,954 miles
2006 ZX10R-Street/Track bike- Only mods -1 Front Sprocket, Exhaust Baffle Kit.
2015 R1 (not stock) Imagine that
BusaCaptain is offline
post #7 of 14 Old 06-29-2012, 04:17 PM Thread Starter
27 hot... as per pirelli...
took 2 clicks out of rebound, didnt see to change much
post #8 of 14 Old 06-29-2012, 04:43 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
try 26.5 psi...hot..see what happens..I got diablos corsa 3 and run 32 at the track hot..Mine are clean..never say there was a track day and a weekend of track school on them..
My buddy races an r6 with sc2 and his are same,clean with 26.5.....Play with pressures and see what works for you..
craig_sez is offline
post #9 of 14 Old 06-29-2012, 08:07 PM Thread Starter
tried up to 29 and as low as 26.... seems they are toast and not going to clean up.. but i want to sort it out before i end up destroying another set
post #10 of 14 Old 06-29-2012, 08:10 PM
fireman69's Avatar
That looks like cold tearing. The fact that you are past the wear bars tells me that it has been going for some time so any changes you made as of recently will be null.
What type of track are you on? Long and fast? Slow corners that you drive hard out of? What level of rider are you? are you using tire warmers?
Let me know, I may be able to help.
fireman69 is offline
tire question (battalzx bt015 front/bt016 rear) question fit for a n00b wicked General Motorcycle Discussions 6 06-24-2012 11:29 AM
gen 1 tire question feo_mack01 General Motorcycle Discussions 6 05-25-2011 01:41 PM
Another tire question... highsider The ZX-10R 2 03-01-2009 07:43 PM
Tire question Janus The ZX-10R 4 01-27-2009 11:17 PM
Tire Question for 06 modpup The ZX-10R 2 07-04-2006 12:49 PM
