Tire Heat Cycle?!?!?!?!?!?!?! - Kawasaki ZX-10R.net
 1Likes
post #1 of 11 Old 06-10-2012, 05:01 PM Thread Starter
Heavyweight's Avatar
What exactly does this mean??? What happens during this?
Livin The Dream
Heavyweight is offline
post #2 of 11 Old 06-10-2012, 05:26 PM
Does not drive into smoke
El Zilcho's Avatar
It's heating-cooling cycle for tires. Before you go on the track, the tires are cool. When you're riding they heat up and after you're done they cool down again.
Exactly what happens I don't know, but race tires are made of a mixture of different compounds, the physical properties of which change as the tires warm up and cool down. To avoid premature wear, it's advisable to keep them at the operating temperature between riding sessions.
El Zilcho is offline
post #3 of 11 Old 06-10-2012, 05:47 PM Thread Starter
Im running a race take off right now and from what ive heard, this is dangerous because it could slide out?
Livin The Dream
post #4 of 11 Old 06-10-2012, 06:45 PM
SkyDork's Avatar
Yes, it's not good to run race tires on the street. Primarily because they are designed to grip at a certain temperature. A temperature that you can not get to on the street and certainly can not maintain.
Also, race rubber has limited heat cycles. As EZ mentioned above, it's the heat up and cool down of the rubber. Race rubber is designed without the preservatives and additives that keep the tire oils from permeating out of the rubber. A race tire is built to withstand about 8-10 heat cycles. After that, is basically shot, regardless of the amount of rubber still on it. It just gets too hard and will not grip any longer. That's why you see racers using tire warmers. They get the rubber up to temp and keep in there so it has minimum heat cycles.
You're risking a lot running a race take-off on the street.
White Fang likes this.
#WordCrimes
SkyDork is offline
post #5 of 11 Old 06-10-2012, 06:49 PM
Boomer0369's Avatar
El Zilcho is correct. The heat cycle is the time between when your tires heat up and cool down. During the manufacturing process the rubber is CURED at a specific temperature depending on the type of rubber the curing is what makes it malleable or harder. No matter the compound the enemy of rubber is heat, especially during heating and then cooling cycle this makes the oils and other compounds come to the surface also known as seeping. Tires that have repeatedly gone through this process will have a bluish tint on the edges. This happens also regardless of riding them or not rubber has an effective shelf life once tires are produced they continue to cure I.e making the compounded harder and harder from reaction with the air and ambient temperature. How long that shelf life is depends on the type of rubber compound. There are some rubber compounds called cleaner stock that due to their chemical composition pretty much makes them immune to the curing process but unfortunately this compound cant be used to make tires as it wont hold form. I used to work in the rubber industry manufacturing tires and vehicle rubber sealing systems.
Boomer0369 is offline
post #6 of 11 Old 06-10-2012, 07:55 PM Thread Starter
thanks for all the responses, i have noticed it not as grippy as it was at first, seems to want to slide in the corners
Livin The Dream
post #7 of 11 Old 06-22-2012, 07:40 AM
kman0066's Avatar
Race tires aren't good for the street because they are meant to be operated at a higher temperature. They don't stick very well when they're cold and street speeds do not put enough heat into them. They should also be used with tire warmers.
But as for heat cycles, here is a quote from Dunlop Racing:
"Heat Cycles is not an issue with Dunlop racing tires. The more important factor is how much tread is left on the tire. Stable fact: thicker rubber has more grip and develops more heat, thinner rubber has less grip and runs cooler. After each session you have less grip. As the tire wears out, you have less and less grip. It could be slight or it could be large.
Some riders call it heat cycling, but, in actuality, its the rubber getting thinner and thinner. It truly depends on how much the tire is worn out, and your specific demands for grip that determines when the tire is not usable for you."
kman0066 is offline
post #8 of 11 Old 06-27-2012, 09:10 AM
Cloud 9's Avatar
since when is a heat cycle not an issue.
dunlop are not imune to the heat cycle.
and as for 8 to 10 heat cycles in a set of tyres that would be a exception rather than the rule.
from memery the new R10's and the S20's are designed for higher heat cycles dew to those tyres being made for the track day heros and the R10 a control tyre for some classes of raceing.
4 or 5 is more it. a race tyre is normaly shot after a days racing. a track day tyre maybe 3 to 4 track days.
as said above a race tyre isn't going to get hot on the street unless you pushing really hard OR running it real soft.
in which case you might as well run 50 psi for all the grip your going to get from a cold race tyre on the street.
i dought a street tyre is affected by heat cycles mainly because they don't get that hot riding on the street. you may think they do but in reality they not getting to the 85-86 deg C that is the sweet temp according to some experts as the ideal temp for maximum grip for a race tyre.
i'm a sceptic of the BS some tyre companies put out.
look at the reconmended tyre pressures where do they get that shit, way the fuk out.
my 2012 zx10 has recomended 36F 42R cold on the stock rubber,, pressures are higher for replacement rubber.
thats fine if you are into drifting i weight 75KG's and 30F and 30R solo is good grip and feel well thats what i get anyway. and 34F 36R 2 up from stock BT016's. 003's are more like the 2 up pressures of the 016's because their softer & stickier
Cloud 9 is offline
post #9 of 11 Old 08-17-2015, 11:37 PM
Proof is in the results. I have run a tire , set it in my shop for a year then put it on a long street ride (150+ miles) then took it out to the local club event a week later and won a 20 lap race setting a "faster than most can can do" pace. Use discretion and feel them out. We all know where we stand in this game and if you want to push your personal limits don't do it on aged rubber...unless you're broke...but stay clear of those that spent the money on the good rubber because they don't want you crashing into them...btw they were Michelin Slicks
RTillery is offline
post #10 of 11 Old 08-18-2015, 10:46 AM
White Fang's Avatar
Back in the day the "heat cycle" used to be a concern for DOT race tires, but Dunlop now says heat-cycling is not a problem with the Q3, for example. It is a matter of the rubber getting thinner which is a natural wear characteristic. Tire warmers won't affect this. Again, this is from Dunlop directly:
Heat Cycles is not an issue with Dunlop racing tires as it would be with other brands. The more important factor is how much tread is left on the tire. Stable fact: thicker rubber has more grip and develops more heat, thinner rubber has less grip and runs cooler. After each session you have less grip. As the tire wears out, you have less and less grip. It could be slight or it could be large.
White Fang is offline
Cycle Hill Motorcycle Tire Changer zapp General Motorcycle Discussions 1 06-07-2009 05:21 PM
New tire for Free from Cycle Gear..Warranty!!! bluedevil General Motorcycle Discussions 4 04-12-2008 06:52 AM
Tire Review: Dunlop N-Tec DOT rear race tire wsmc27 Track 4 08-09-2007 03:14 PM
How Much Heat war1000 The ZX-10R 5 05-24-2006 10:13 AM
Sun And Heat? Iceman The Out House 6 06-26-2005 12:24 AM
