Tire Changer: Who's using this one? - Kawasaki ZX-10R.net
post #1 of 12 Old 10-07-2012, 08:02 PM Thread Starter
southpw11's Avatar
I've done a few searches, and see people are using expensive or home-made tire changers.
Is anyone using this one?
http://www.ebay.com/itm/2-in-1-Porta...92b728&vxp=mtr
I'm curious because someone posted that they were and it looks like the center post might be too large for the axle hole on a zx10 to fit into.
southpw11 is offline
post #2 of 12 Old 10-08-2012, 10:33 AM
nakedinseattle's Avatar
Changes tires on motorcycles with a center hole larger than 1-5/8" or a removable center hub
that should answer that. that style of changer works well, the first few times you'll hate it but once you get used to it, pretty easy.
nakedinseattle is offline
post #3 of 12 Old 10-08-2012, 12:09 PM Thread Starter
southpw11's Avatar
do you mean its too large for a zx10 axel? ive not changed my tires yet.
post #4 of 12 Old 10-10-2012, 01:35 PM
Always On Mod
Animal11's Avatar
I have this model, but it's also the same one Harbor Freight used to sell for $100. THE BAR WILL SCRATCH YOUR WHEELS. I coated the ends of my bar with plasti-dip and that seemed to help. That one looks painted in the pics, but i'd be really careful. Rim savers work really well to keep the spoons from scratching when you need to pry the tire off.
I've changed 4 sets with it now, and it requires a lot of grunting and pushing/pulling. Lube is your friend.
I found mine on Craigslist for $50 local, for the money I would invest in one of these for a bit more. http://www.nomar-secure.com/category_s/1.html
No-mar also sells just their bar I'm probably headed this route to avoid adding more scratches
Animal11 is offline
post #5 of 12 Old 10-18-2012, 02:55 PM Thread Starter
southpw11's Avatar
I did my first tire change on the homemade tire changer posted here, and using a normar bar.
https://www.zx-10r.net/forum/showthre...t=tire+changer
It was a bear, since my station was up high and a little cramped but it worked finally (after resorting to spoons).
I bought the harbor freight looking tire changer in the original post, which I'll use to change the front tire.
post #6 of 12 Old 10-20-2012, 10:45 PM
The ebay unit looks just like the Harbar Freight one.
Slowestrider is offline
post #7 of 12 Old 10-21-2012, 12:14 AM
I use two tire irons and the items below. I wrap the bead breaker with a soft towel just in case it makes contact with the rim. Dishwashing soap helps lube the beads on mount/dismount. With enough lube & practice, you can get the tires on/off with minimal use of the tire irons. I love my rims and I won't let anyone else touch them. Harbor Freight also sells a cheap balancer. Primer/spray a bunch of wheel weights white/black beforehand that way they blend in nicely with your wheels.
http://www.harborfreight.com/bead-breaker-92961.html
littlefreak is offline
post #8 of 12 Old 11-13-2012, 10:41 PM
speedy14's Avatar
Use that changer but tape up the clamps so they do not scratch the rims. Order a NoMarr bar and balancer and you are good to go. Mount the tire changer to a solid surface or it is a hassle to use.
I mounted mine to two 2x6's. crossed under them so I can stand on them while using the tire machine but then store it later. It can be a hassle sometimes but works well.
Speedy
speedy14 is offline
post #9 of 12 Old 11-13-2012, 11:25 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
I have the Harbor Freight tire change.
I then purchased the "Mojo Lever", it has the Delrin plastic demounter and bead seated.
Best money spent. Use some dish soap and water and goes on and off like butta.
I also bought the Delrin clips that mount to the tire change itself.
Check out Mojo lever, that shit works. Bar none.
hellsrazor is offline
post #10 of 12 Old 11-14-2012, 09:27 AM Thread Starter
southpw11's Avatar
Speedy
Yea i ended up getting that ebay (same as old harbor freight one) tire changer, one of those ebay balancers, the no-mar bar, and a no-mar 'yellow thing' (thats the actual name). I mounted the tire changer to a pallet so it's pretty stable.
The tire changer worked well but there are 3 things I noticed. First, like you said, you have to put something on the clamps or your rim will get scratched. I used t-shirts cause I didn't have anything else at the time; the shirts ripped a little and ended up scratching the rim a bit. I'll use tape or something else next time.
Second, you have to clamp down the wheel really hard or it will rotate and make the job impossible.
Third, the tire changer sits up kinda high so when you're using your body leverage to put the tire on, the bar is sitting above your stomach or on your chest almost (instead of your waist/stomach). Makes using leverage a little harder, but not impossible.
Overall, changing the tires were really hard for me...but I think if you use good technique it's not that hard at all. My second tire change was a lot easier than the first.
No-Mar Tire Changer PJD General Motorcycle Discussions 10 06-08-2012 01:08 PM
Wanted: Tire Changer SnapThrottle Wanted: Buy or Trade 1 05-26-2011 02:06 AM
No Mar tire changer zx10Duran Race and Stunt 1 04-03-2010 01:03 PM
No Mar Tire Changer badboyrr The Out House 20 09-01-2008 11:33 PM
tire changer hongthaomurphy The Out House 17 10-27-2005 11:51 AM
