Stock BT-016 front wears faster than rear - Kawasaki ZX-10R.net
post #1 of 14 Old 09-04-2013, 10:51 AM Thread Starter
Lobster's Avatar
Took the bike around some really mild sweepers at like 60-75 mph. Stock suspension sag and rear shock shimmed so the rear is raised a little. I've been told the Gen 4 almost requires rear shimming.
I'm only 145 lbs so I'm not a heavy guy stressing the front end. They were mild sweepers. I didn't even brake before, during, or after the turns. There were only 15-20 turns and I only spent 30 mins riding these turns that are mostly lefts. I thought I put a lot of stress on the rear when coming out of the sweepers but my rear is still good.
Although I was kneedragging it was only at 70 or so.
I've been riding for years and never experienced something like this. I've beat down tires on the track and still had some tread. Riding this past weekend was VERY mild.
Are stock Bridgestones prone to wear? I have a set of Q3s going on it but I don't want to instantly wear the front after a few turns.
Left side is bald.
Lobster is offline
post #2 of 14 Old 09-04-2013, 10:52 AM Thread Starter
Lobster's Avatar
2900 miles on tires. Very slow rider.
Should I remove the rear shim?
Rear.
Lobster is offline
post #3 of 14 Old 09-04-2013, 11:55 AM
vr6
Rear.
Those bt016 wear fast on front tires it's been discussed at lenghth it's not your set up or ridding style. My front is worn too and the rear looks new. Q3s should be real nice. I'm going with Bridgestone hypersport s20r.
Wow just noticed your wear pattern. My front tire is at the lip/edge and my rear has the chicken strip. I need the rear shim because I see now I'm way more biased to the front tire.
vr6 is offline
post #4 of 14 Old 09-05-2013, 02:09 PM
bennice's Avatar
^^^ this.
I had the same experience on my gen 2. Did not dig those tires at all over the long haul.
bennice is offline
post #5 of 14 Old 09-05-2013, 10:43 PM
Tech5's Avatar
same here too lobster
The Truth
Tech5 is offline
post #6 of 14 Old 09-05-2013, 10:54 PM
I had the same tires on my gen 3 and around 2000 miles. my back tire was as slick as could be.
jeffy19931 is offline
post #7 of 14 Old 09-05-2013, 11:01 PM
Tech5's Avatar
the back tends to last longer then the fronts with these tires, I wouldn't use them unless they came on the bike.
The Truth
Tech5 is offline
post #8 of 14 Old 09-06-2013, 12:17 PM
Its normal. After only 1100 miles on the stock front, I had the front literally looking like ^ and completely slick on both shoulders and deep tread in the middle.
2008 ZX-10R. | Full Arrow exhaust | PCV | AutoTune | BMC Race | Driven -1+2 520 conversion | Speedohealer | Spiegler braded lines | Carbone Lorraine SBK5 | Dunlop Q3 | more to come.
IggyBcool is offline
post #9 of 14 Old 09-06-2013, 04:59 PM
TechX's Avatar
I wore out the front bridgstone on my Gen 3 before the rear which is really weird. Must be a bridgstone thing.
TechX is offline
post #10 of 14 Old 09-06-2013, 06:27 PM
Sasquatch's Avatar
This is weird. I have never once defended a tire for getting long life but my 016s are doing great. The front still has a ton of life in it. The rear is getting chewed up a bit on the sides-maybe 20% left at best on the sides and a fair bit more down the middle. I have close to 3000 on the set.
Have a wheelie nice day!
Winter sucks.
Sasquatch is offline
06 10R heat shield, stock wind screen, front seat, front fender, pass. rear sets jhud Parts, Gear and Accessories 9 10-02-2009 03:05 PM
Off Shelf BT-016 Rear Hard Compound SP8 General Motorcycle Discussions 8 05-29-2009 08:06 PM
Bridgestone BT-016's Front and Rear 08ten Vendors deals 4 03-27-2009 09:14 AM
16t in the front Stock in rear TKD-NINJA The ZX-10R 18 06-21-2005 08:59 PM
stock front/rear turns on 05 the same? steves87 The ZX-10R 3 05-30-2005 09:32 AM
