Spanner wrench or chisel and hammer? - Kawasaki ZX-10R.net
post #1 of 10 Old 01-26-2015, 11:25 PM Thread Starter
drbyers's Avatar
So I'm trying to sort the suspension on my 2012. The shock is extremely hard to reach up in there because of the horizontal layout.
Do you guys use a spanner wrench to adjust the shock spanners or just bang the hell out of the spanners with a big screw driver/chisel and wrench?
I'm thinking the latter.
drbyers is offline
post #2 of 10 Old 01-27-2015, 12:22 AM
Always On Mod
Animal11's Avatar
if you don't have the wrench, I would use a dull punch, or a long screwdriver that's dull. A chisel will cut into the tabbed rings and has a high likelihood of scratching something you don't want to
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #3 of 10 Old 01-27-2015, 06:33 AM Thread Starter
drbyers's Avatar
i've got the spanner wrench and a short punch, but of course. I guess will have to get a longer one.
drbyers is offline
post #4 of 10 Old 01-27-2015, 08:29 AM
SkyDork's Avatar
If you're gonna go the beater route, then get a long flat punch to do it. A screw driver will chew up the notches on both the locking and preload collars. Especially if tightening as more force is required to spin them as the spring compresses. The spanner is the best, but it's tight in there. Invest in a quality punch and go at it that way.
#WordCrimes
SkyDork is offline
post #5 of 10 Old 01-27-2015, 10:01 AM Thread Starter
drbyers's Avatar
Longer punch it is.
drbyers is offline
post #6 of 10 Old 01-27-2015, 06:12 PM
evallarta1's Avatar
If you can have someone lift the rear and take some pressure off the spring, makes using the spanner much easier.
Velocity Calibrations
evallarta1 is offline
post #7 of 10 Old 01-27-2015, 06:17 PM Thread Starter
drbyers's Avatar
Good idea. Lol
drbyers is offline
post #8 of 10 Old 01-27-2015, 07:15 PM
evallarta1's Avatar
Originally Posted by drbyers View Post
Good idea. Lol
Lots of times Ill con my riders to hold up the rear while I change sag.
post #9 of 10 Old 01-28-2015, 10:36 AM
I've used an adjustable filter pliers before. (not sure if you have room for that or not)
silversixspeed is offline
post #10 of 10 Old 03-23-2015, 02:43 PM
Good Advice!
cyclepath is offline
spanner wrench?? spanky3780 The Out House 9 10-29-2007 11:24 AM
Spanner wrench. ZX10 Guy The Out House 4 09-09-2007 01:50 PM
Spanner Wrench Rick-ster The ZX-10R 6 02-06-2007 08:31 PM
spanner wrench. rocketracermike Performance and Tech 23 01-07-2006 04:49 PM
preload spanner wrench king-tony Performance and Tech 4 04-14-2005 09:01 AM
