Shock compatibility between gens - Kawasaki ZX-10R.net
 1Likes
post #1 of 13 Old 06-07-2016, 03:17 AM Thread Starter
I did have a search but couldn't find anything definitive, sorry if this has been asked a million times.
But which gen shocks are compatible with other gen bikes?
I have a gen 1 and am wondering if an ohlins or aftermarket shock from other models will fit. From what i've read a gen 3 and gen 1 will swap - but the others are unique to themselves.
Is the gen 3 a straight swap onto a 1? Only i was under the impression the width of the clevis and pin through the linkage is different? Hopefully the pin could just be swapped...
thanks
craig_ is offline
post #2 of 13 Old 06-07-2016, 08:14 AM
SkyDork's Avatar
You're right, Gen 1 and 3 will swap. Gen 4 and 5 will also. But that's it.
#WordCrimes
SkyDork is offline
post #3 of 13 Old 06-07-2016, 09:18 AM
Ryan66's Avatar
4 will not swap to a 3 with the 4 linkage?
Ryan66 is offline
post #4 of 13 Old 06-07-2016, 09:47 AM
SkyDork's Avatar
Not a chance. The gen 4 shock is horizontal. The gen 3 is vertical. The reservoir on the shocks are a completely different arrangement. The swingarm on the gen 3 would hit the gen 4 shock.
#WordCrimes
SkyDork is offline
post #5 of 13 Old 06-07-2016, 10:19 AM Thread Starter
That's great, thanks man
So is the gen 1 and 3 a simple straight swap, bolt in, no changes at all?
craig_ is offline
post #6 of 13 Old 06-07-2016, 10:30 AM
SkyDork's Avatar
From what I remember of it, you have to change out one of the collars on the shock to accept the different size bolt. Or it gets drilled out. Can't remember and I'll have to search for it. I know a guy who ran a stock gen 1 shock on his gen 3 and did quite well at the track on it. But there was a slight modification he had to do to mount it.
#WordCrimes
SkyDork is offline
post #7 of 13 Old 06-07-2016, 10:51 AM
evallarta1's Avatar
You have to look at more than just "will it fit". Example of this is the Gen 1 Ohlins shock has 69mm of stroke where the Gen 3 has only 64mm of stroke. BUT they are both the same overall length out of the box. So by fitting a Gen 3 shock you'll be losing stroke which can affect bottoming.
Velocity Calibrations
evallarta1 is offline
post #8 of 13 Old 06-07-2016, 11:01 AM Thread Starter
skydork - yeah i thought it would be something like that - thanks
evallarta - yeah of course there's that to look at but i wouldn't think 5mm stroke on the pretty smooth tracks i have around here should make much odds - it's not like with the forks where under heavy braking you're always working pretty low in the stroke.
Having said that the simple solution is just to wait for the correct gen ohlins to come up!
thanks guys
craig_ is offline
post #9 of 13 Old 06-07-2016, 01:07 PM Thread Starter
What's your opinion on using shocks from different bikes in general?
If the overall length and stroke lengths are close/the same should it be ok in theory? Or can the valving etc all be way out too?
Just been researching shocks from other bikes and it seems some years of gsxr and hayabusa use a 330mm shock, compared to the zx10 338mm. Obviously that difference could be made up with a shim and/or the height adjustment of an aftermarket shock.
The gsxr shock stroke is actually 72mm or 74 on the busa i think it is - so surely an extra 3mm isn't a problem either.
So in a case like that, as long as the width of the clevis and top eye were correct or could be sorted would that kind of thing pass?
I guess the busa shock is a crap choice cos it's a big heavy tourer! lol, but a gsxr 1000 is of a similar weight and bike?
I know it seems stupid but here in the UK it's much easier to find a used ohlins from a suzuki than a gen 1 zx10!
craig_ is offline
post #10 of 13 Old 06-08-2016, 03:04 AM
57x
I've done it, but it is not perfect. It works well on the street, but I would never do it on the track as a direct swap. There is way more to a shock than just length and stroke. Having said that, if you find a shock off another bike that has the overall height you need with enough stroke, you could have the valves changed during a rebuild and get it correct. I have done that on track bikes a couple times and it worked great.
evallarta1 likes this.
57x is offline
Gen 4: Wheel compatibility dudewhrsmybike Performance and Tech 72 07-12-2018 02:52 PM
Rear shock compatibility. Omofo Performance and Tech 6 02-08-2013 12:55 PM
Gen 3: Shock compatibility Magmadragoon Performance and Tech 1 02-14-2012 05:40 AM
Shock compatibility questions fireman69 Performance and Tech 11 05-04-2011 11:59 PM
PCIII compatibility. Nutter34 Performance and Tech 10 07-08-2010 07:44 AM
