Shock adjusting made easy lol - Kawasaki ZX-10R.net
 2Likes
  • 2 Post By ukzx10r
post #1 of 7 Old 06-05-2016, 04:48 PM Thread Starter
Want a laugh?
Ive always been hacked off with having to remove the rear shock just to adjust the preload nuts.
So i thought im gonna try something a bit different.
Three 12mm cable ties 500mm long.
Thread them through your shock spring.
(Not easy but it helps having a 11 year old with small hands)
Sit on the bike whilst tightening the ties.
Then tip the bike onto sidestand and lift rear wheel off the ground.
Very easy to do if you got not cat.
You just sit it on an axle stand.
Spring is relieved.
Tap lock nut undone.
Use blunt piece of bar. Preferably alloy to gently tap the preload nut round.
I even managed it with 2 ties but i rccomend more as the spring generates large forces.
Cut the ties off when done.
Be careful obviously.
g-man and Siwa like this.
ukzx10r is offline
post #2 of 7 Old 06-20-2016, 12:40 AM
Mr Wong's Avatar
That's brilliant!
Must give it a try.
Mr Wong is offline
post #3 of 7 Old 06-20-2016, 02:41 AM
Siwa's Avatar
Nice man. I was actually looking at mine the other night while having a smoke and thinking to myself "Can't be f*cked.".
2016 - ZX-10R KRT Winter Edition
https://www.instagram.com/superbike.turtle/
Siwa is offline
post #4 of 7 Old 06-20-2016, 06:13 AM
ZX10's Avatar
I gota a silly question, how would you do your static sag and rider sag that way
ZX10 is offline
post #5 of 7 Old 06-20-2016, 02:15 PM Thread Starter
Just by guessing roughly where it needs to be and doing it again until its right. If you turn the nut with the spring touching it you will scrape all the paint off.
ukzx10r is offline
post #6 of 7 Old 06-20-2016, 05:19 PM
evallarta1's Avatar
While I commend you for thinking outside the box, doing this probably is not the best.
If you want to alleviate some pressure off the shock spring you can drop the tire like already mentioned and adjust the collar (minus the zip ties). This will make spinning the collar much easier then having the rear tire on the ground.
Velocity Calibrations
evallarta1 is offline
post #7 of 7 Old 06-21-2016, 04:19 AM Thread Starter
No the spring is still under alot of pressure even when the shock is unbolted off the bike.
ukzx10r is offline
Christmas Shopping Made Easy ridersdiscount Riders Discount 6 12-07-2012 08:34 AM
Gen 4: Adjusting oem rear shock Rooter The ZX-10R 11 07-01-2012 02:13 PM
Learn To Set Your Own Suspension Made EASY hellsrazor The ZX-10R 56 05-03-2012 10:04 AM
lol easy entertainment farmerfred240sx95 The ZX-10R 2 11-16-2011 11:41 AM
adjusting 08 rear shock preload spikespiegel Performance and Tech 2 12-06-2008 07:45 PM
