Sealmate-Sealsaver - Kawasaki ZX-10R.net
post #1 of 8 Old 12-09-2014, 02:56 AM Thread Starter
ikaika's Avatar
Sealmate-Sealsaver
I just noticed I had a small leak on my left fork tube. I was just curious if anyone has any experience with Seal Mate made by MotionPro? Also, does anyone use Sealsaver on their fork tubes?
Custom FE/CA taillight/TechSpec/Driven D-Axis gas cap/Cox Racing/Champs frame-fork-swingarm sliders/Puig ZRacing/Titax/Woodcraft-Attack case covers/SME rear axle block sliders/Misc carbon fiber/ZG Latigo/HID's/M4 Street Slayer/BMC/XTre/EK 520 MVXZ/+4 Drive Sys/SpeedoHealer/HEL 'Stealth'-Motul RBF600-Galfer pads/KyleRacing damper/Rifleman's/Ivans b/o plates/Q3's/Motul 300v/Engine Ice/Shorai
http://www.maresohana.com/ktrsd
ikaika is offline
post #2 of 8 Old 12-09-2014, 03:20 PM
evallarta1's Avatar
I used to keep MP Seal Mates in my bag when I tune suspension at the track. They work pretty well, but they flex a lil too easy. I use/sell the Seal Doctors and love them! The first time I used it I threw all the MP away.
http://www.riskracing.com/pages/Seal...l#.VIdlvCejUy4
They are a bit more expensive but they last forever.
Also dont bother with sealsavers for a couple reasons. First and the worst, they trap crap. If you don't clean them regularly they will destroy your forks. Second they greatly increase stiction. And last if you do regular maintenance on your forks like the rest of the bike you dont need seal savers.
Velocity Calibrations
evallarta1 is offline
post #3 of 8 Old 12-10-2014, 02:03 PM
GlassAnkles's Avatar
Seal savers with trap dirt and grind it into the tube, id pass on those. I tried them on a KTM when i was riding enduro.
GlassAnkles is offline
post #4 of 8 Old 12-10-2014, 02:11 PM
or10r's Avatar
So you use these the same as shown? Just pry the dust seal off and and circle the oil seal a few times?
or10r is offline
post #5 of 8 Old 12-11-2014, 11:44 AM
evallarta1's Avatar
Correct. Saved about a dozen riders from loosing out on their trackday due to a leaky seal.
post #6 of 8 Old 12-11-2014, 03:34 PM
evallarta1's Avatar
Also I'd like to point out that this is NOT a cure for leaking seals. These and the Motion Pro Seal Mates are intended to get you through your ride/day so you can get home safely and inspect your forks/seals properly.
post #7 of 8 Old 12-18-2014, 07:27 PM Thread Starter
ikaika's Avatar
Update....I have a Seal Doctor on its way but went to my local shop and picked up a MP Seal Mate for $5.00. Followed the instructions and it's been 9 days with absolutely no leaks. Seal Mate is flimsy but worked. The Seal Doctor looks like a better quality product, though more expensive, but seems like a perfect little item to add to my tool box
ikaika is offline
post #8 of 8 Old 12-18-2014, 09:17 PM
Matteson's Avatar
Use a thin feeler gauge instead. Typically we have them lying around the shop. But as mentioned, this isn't a permanent solution.
Matteson is offline
