replacing fork seals with ohlins inserts - Kawasaki ZX-10R.net
post #1 of 4 Old 06-10-2016, 02:56 PM Thread Starter
Always On Mod
Animal11's Avatar
my fork seals have started weeping again on my 2011, but this time I have the ohlins 30mm inserts installed. I don't remember the install process enough to remember if I'm going to need any special tools? Anyone know enough to shed some light?
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #2 of 4 Old 06-10-2016, 07:59 PM
I haven't personally worked with ohlins carts yet, but their fork caps require a special socket.
Darkraven is offline
post #3 of 4 Old 06-13-2016, 10:20 PM
You would need the ohlins cartridge tool which is available on bike bandit.com ... A bit expensive at 125$ and you would need a pin spanner to remove the top cap of the forks... Can't think of any other tool you would need
Ranjit1194 is offline
post #4 of 4 Old 06-13-2016, 10:27 PM
Although you need to double check as it's a BPF on your 2011 and I'm not sure if you would need any other special tools
Gen 3: replacing my fork seals what do i need? C Murda The ZX-10R 8 03-27-2012 12:22 PM
Replacing fork seals for the first time? motonick8503 Performance and Tech 5 07-27-2010 11:37 PM
Fork Seals: Help with Removing Fork Cap ('05 ZX-10R) Henry The ZX-10R 3 08-16-2009 10:40 PM
Replacing fork springs afskypilot Performance and Tech 15 05-21-2008 05:38 PM
trouble replacing fork seals logmaster Performance and Tech 15 06-19-2007 11:14 PM
