Rear tire pressure - Kawasaki ZX-10R.net
post #1 of 8 Old 03-30-2013, 05:17 AM Thread Starter
Back in 10's Avatar
Rear tire pressure
What tire pressure are people setting at for drags?
I'm sure track conditions.. riders weight.. etc. are factors.
170lbs.. 190/50pilot powers..
Back in 10 is offline
post #2 of 8 Old 03-30-2013, 01:35 PM
Post Whore
-Op-'s Avatar
Is your bike stretched or does it have any serious power adders?
Stock wheel base, you probably wont need to play around much with the pressure just because its more likely that the bike will wheelie than it will spin.
Stretched will depend on track prep. The better the prep, the more air you can run. At my local 1/8mi the prep is pretty good and I had no problem hooking up with my 190/55 Pilot Power @35psi when I was stretched 6" over, -1/+5 gearing and lowered/strapped.
-Op- is offline
post #3 of 8 Old 04-01-2013, 03:11 AM Thread Starter
Back in 10's Avatar
Yea stock wheel base.. Was just trying to eliminate some wheel spin off the line..
Had pilot pures 190/55 but wouldnt hook up for crap so i went back to the pilot powers 190/50.. Not set up for drags just wanted to make the best of what i had to roll with..
second butterfly removed.. akrapovic slip on.. 16/40.. balls..
post #4 of 8 Old 04-01-2013, 03:30 AM
Post Whore
-Op-'s Avatar
What PSI have you been running it at? Are you doing a burnout before your pass? Drop 5 PSI out of em and see if that solves your issue.
-Op- is offline
post #5 of 8 Old 04-01-2013, 03:35 AM Thread Starter
Back in 10's Avatar
bout 35 32.. burn out most of the time.. watched videos n see wheels spinning more then i think it shold or i could be wrong.. i soften rear suspention a little too..
post #6 of 8 Old 04-01-2013, 03:48 AM
Post Whore
-Op-'s Avatar
Give 26-28 a try and see how that responds.
-Op- is offline
post #7 of 8 Old 04-01-2013, 03:56 AM Thread Starter
Back in 10's Avatar
aight will do.. Thnks for taken time to reply..
post #8 of 8 Old 04-01-2013, 04:25 AM
Post Whore
-Op-'s Avatar
No prob. Im by no means the fastest guy or smartest guy on this subject, but Im just passin on whats helped me through my past year of drag racing
-Op- is offline
Tire Pressure 09zx10miami Performance and Tech 20 09-23-2010 08:39 PM
Recommended rear/front tire pressure on a 2007 ZX10 aneconsulting The ZX-10R 37 02-17-2010 08:22 PM
tire pressure 04ZX10 The ZX-10R 2 10-01-2006 11:38 PM
tire pressure kuzco The ZX-10R 13 05-19-2005 11:45 PM
Tire pressure Balto The ZX-10R 8 06-25-2004 02:55 PM
