Rear rotor screws touching brakes bracket - Kawasaki ZX-10R.net
post #1 of 9 Old 05-10-2013, 08:44 AM Thread Starter
hitithard's Avatar
Well i finally installed my wheels after getting them Power coated. The issue that im having now is that for some strange reason i have my rear rotor screws touching the brake bracket. What can this be?
hitithard is offline
post #2 of 9 Old 05-10-2013, 09:19 AM
SkyDork's Avatar
Pics? Something is misaligned or not installed right.
#WordCrimes
SkyDork is offline
post #3 of 9 Old 05-10-2013, 09:47 AM
The Pace
scout's Avatar
forgot to spacer.
scout is offline
post #4 of 9 Old 05-10-2013, 01:49 PM Thread Starter
hitithard's Avatar
I did lost my spacers put ended up getting some from Ke2012 that he was selling. I will post some pics when i get home.
post #5 of 9 Old 05-10-2013, 04:09 PM
PatrickG's Avatar
Images: 15
Too easy.. There is powdercoating in the shouldered part of the hole. The bolt is tight or so it thinks so but it is really jammed into the hole.
Same crap happening when you get stuff "chromed"
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #6 of 9 Old 05-10-2013, 08:54 PM Thread Starter
hitithard's Avatar
No it wasn't the powercoating..06blackpearl did a great job on my wheels. The problem was the mechanic that put my bearings back. He ended up freaking putting the front bearing on the rear wheel.
post #7 of 9 Old 05-10-2013, 09:00 PM
bluedevil's Avatar
Very Sad that's why I like doing my own stuff even If I have to learn Powercoating hard to trust anyone to take care of your bike with simple details.
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #8 of 9 Old 05-10-2013, 09:44 PM
PatrickG's Avatar
Images: 15
SWEET!!! 06BP doesn't awesome work!!!
PatrickG is offline
post #9 of 9 Old 05-20-2013, 08:03 PM
Better get the oem spacer just to be safe and avoid further damage to the rotor and wheel. Also make sure to get a competent mechanic.
kartl is offline
Rear caliper bracket hitting rotor? harrow728 The ZX-10R 5 06-07-2012 02:48 PM
Wanted: looking for rear axle,nut, swingarm blocks and spacers and rear caliper bracket for brijesh600 Wanted: Buy or Trade 4 10-31-2011 08:26 AM
WTB rear passenger pegs screws for 06-07 zx10 littlenoodleboy Wanted: Buy or Trade 0 02-18-2011 12:28 AM
Loctite in rotor screws..... 1bad10r Performance and Tech 9 01-10-2008 01:35 PM
Rear rotor??? STREETFIGHTER50 The ZX-10R 6 11-29-2004 02:13 PM
