Reading Slicks - Kawasaki ZX-10R.net
 8Likes
post #1 of 24 Old 05-09-2019, 12:19 AM Thread Starter
Reading Slicks
I've searched the forum and found little useful, but seems like there are some fast guys here so:
Attached is a photo of the rear tire with rotation indicated.
The trailing edge of wear hole (when rotated to top) is torn severely rearward. The side holes are torn almost 90 to the outside (slightly rearward when rotated to top)
Other:
Dunlop 200/55 Med+.
24psi hot off track, and slightly lower off warmer.
I cut the rubber balls from the tire edge for balancing.
Disregard the smooth area in center, rode to work so I could change oil and filter warm.
Gen 4, stock suspension.
The tear toward rear I thought was rebound too slow, so I sped it up and she got worse.
1- Is this correct logic?
2-What is ideal for the side hole comet tail to point, and what setting affects it?
-Dork
ID:	422269   Click image for larger version
Name:	2019-05-08 21_1557378267008.44.20.jpg
Dork is offline
post #2 of 24 Old 05-09-2019, 10:08 AM
LDH
LDH's Avatar
Slicks
Stock Suspension
Tire Wear concerns
That's like a 400lb woman counting calories at Baskin-Robbins
michael4012 and Neonmarine like this.
LDH is offline
post #3 of 24 Old 05-09-2019, 10:19 AM
GreenWeenie's Avatar
No cold tearing, so looks all good to me.
Looks about the same as mine.
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
post #4 of 24 Old 05-09-2019, 10:40 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
Personally, I think you've got too much tire movement via soft suspension. Also, your pressure seems a couple psi higher vs how much load you're putting on the carcass. There aren't any tears.
You want the tire carcass to flex in tandem with the suspension. Right now I'd say your tire isn't flexing enough and the suspension is moving to much. Pressures and settings will make this better, but you might be at the limit of the stock shock right now.
Also, the Dunlop slicks is on the harder side of all the tire manufacturers' carcass flex. You might do better with a Dunlop Q4 or something if that's your chosen brand. Competition tires need load and right now, it's not getting enough.
"You must subsume yourself to the bike"-Casey Stoner
"Thereís a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #5 of 24 Old 05-09-2019, 11:24 AM
Be careful with the Q4s. Mine only lasted a single day at Thunderhill. They are soft carcass and soft compound and the big bikes eat em up. I prefer the stiffer Dunlop. (I run an ohlins shock on my 10RR)
This is a Continental slick. It currently has 4 track days on it. I run 23r/33f hot.
Name:	Contislick 3 days.jpg
ID:	422279   Click image for larger version
ID:	422281   Click image for larger version
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
post #6 of 24 Old 05-09-2019, 12:04 PM
Neonmarine's Avatar
Looks good. If it was me, I'd add a pound to see it would get the wear holes to quit the comet trails.
GreenWeenie likes this.
post #7 of 24 Old 05-09-2019, 12:06 PM
Neonmarine's Avatar
And the Q4 is fine if your pace matches it. That's all I meant by that. With his soft suspension, a softer tire will work better.
post #8 of 24 Old 05-10-2019, 06:29 AM
ShawnG's Avatar
Where the hell do you even get these?
ShawnG is offline
post #9 of 24 Old 05-10-2019, 11:10 AM
Special Industry Insider contacts :) .
I think they are popular in the EU, but there aren't any race suppliers in the US that I am aware of.
Search my Post for Continental Slicks demo
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
post #10 of 24 Old 05-11-2019, 02:44 PM
The last picture of green weanies tire is how you want it to look. Like beach sand when the water has receded. No tears and no major lips in front of the wear indicator holes or trailing them. Also the picture should be taken at the track hot off your session. Straight on pictures do not show the best shadows. Slight angled pictures that show the shadows of the topography of the tire are best. Your tire looks pretty good. It looks like you are not too aggressive with the throttle. I would like to see the front to give me an indication of total lean angle. I tend to tune more for best feel and traction than prefect tire wear. Your tire is fine.
The Prophet is offline
Michelin Slicks..good or bad johnnyb-21 Race and Stunt 7 05-09-2006 07:24 PM
FS: Dunlop 208 GPA's & KR106 Racing Slicks mikdivad Parts, Gear and Accessories 2 08-28-2005 10:16 PM
Iím ditching the race dots for slicks! zrxhooligan Performance and Tech 15 07-29-2005 11:45 PM
Michelin Pilot race Scuffs and Grooved Slicks Gixx1300R Parts, Gear and Accessories 4 07-10-2004 01:59 PM
Which slicks? chicken The ZX-10R 1 05-03-2004 09:21 AM
