Reading Slicks - Page 2 - Kawasaki ZX-10R.net
 9Likes
post #11 of 25 Old 05-11-2019, 05:30 PM
GreenWeenie's Avatar
This is my front after Buttonwillow. Im not sure how to read this one...data suggests that it is too much weight on the front ..?! Maybe?
Buttonwillow has a high speed 120mph plus sweeper, entering it at over 160mph...and carrying speed to the exit....pretty sure where this is happening.
At 160+ in order to get the bike to turn, I have to roll off slightly or gently add some brake.... pretty sure thats causing the front to plow.
Suggestions on where to look? The front suspension is stock... :(
D
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is online now
post #12 of 25 Old 05-11-2019, 05:40 PM
Make sure your tire pressure is not too low first. Pretty sure you checked that but......the tire looks like it is working very hard. I would add a couple pounds and check it after a session. That's what I mean by......if the bike feels good, the tire wear is second to the way it is wearing. If your forks are lowered in the triple, you could raise them 5mm and see if you can change the attitude a bit.
The Prophet is offline
post #13 of 25 Old 05-11-2019, 05:42 PM
Riverside turn CCW , yes.
post #14 of 25 Old 05-11-2019, 05:54 PM
Riverside clockwise... no bus stop
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
post #15 of 25 Old 05-12-2019, 02:21 AM Thread Starter
Dork's Avatar
GreenWeenie, I would've been at buttonwillow today too, just wanted to sort this shock thing first.
For TheProphet: The first pic is the front left side, it won't help much bc most was scrubbed off on the oil change ride.
The second is the more shaggy right front.
Fresh off track pics won't be till big willow on the 25th.
2012 Gen 4. I can live with the front but the rear is crummy I hear...wrong linkage, soft damping and spring.
Considering:
1 - rebuilding it with 5wt oil and/or gold valve b4 25th.
2 - slapping on stock gen 5 shock and linkage
3 - (probably not b4 25th) aftermarket shock. My question is: does an aftermarket gen 4 shock need aftermarket linkage?
If so, I wont feel too bad about buying the Gen 5 kit, and keeping the link plates/dogbone with aftermarket shock of choice.
Otherwise I can poop out some copies of the aftermarket link plates and dogbone, run that in 2 weeks on stock shock, then pick out a Penske or Ohlins.
ID:	422301   Click image for larger version
Dork is offline
post #16 of 25 Old 05-12-2019, 02:39 AM Thread Starter
Dork's Avatar
The Prophet:
If you look at the first pics of rear I was mostly asking what adjustments I could try to get rid of the huge tearing of wear holes.
I heard two conflicting things about upping and lowering tire pressure, which what the hell I'll try, but thought rebound would affect it. Tire was untouchably hot, so I figured i was in the ballpark.
Basically I had rebound run all the way in and cracked open, tearing of wear hole was significant, then I backed it out more, and got worse. Led me to believe I was at the limit of stock adjustment. If that was the case I was keen to try something to salvage the stocker...otherwise door stop.
Thanks for contributing, you seem to know your stuff.
Dork is offline
post #17 of 25 Old 05-12-2019, 11:03 AM
D
Similar to what The Prophet said, the tire is getting worked too hard. Either pressure or suspension setting/geometry. For reference, at buttonwillow I run 36 psi hot on a pirelli sc2 front.
Tyler Wolters - AFM #54
WoltersRacing.com
Facebook - https://www.facebook.com/pages/Tyler...02139439887883
2019 Support Ė Capital Edge Financial, Direct Technology, Pacific Track Time, CT Racing, Pirelli Tires, PCP Motorsports, TechSpec, Motion Pro, GP Suspension, Daredevil Motorsports, Vortex, Motonation, Sidi Boots, Forcefield Armour, Suomy Helmets, Cycle Gear, Racer Gloves, Spy Optics, Shorai, GoPro, Braking, Ogio, Wicked Audio.
AFM54 is offline
post #18 of 25 Old 05-13-2019, 05:49 AM
Carlos76's Avatar
You asked similar question in other thread, here is what I know:
a) Gen4 link ratio is arround 2.3, gen5 is where most sport bikes are 2.1. Ohlins for gen4 ships with 110 spring and Ohlins for gen5 with 95 spring. Gen5 has more shaft movement and valving is different too. Gen4 link could theoretically be as good with 10-12% more spring and more shim stack, but in practice people report gen5 setup (MSS, Attach) working better, can confirm this myself.
b) If you get aftermarket shock what is not revalved and has spring arround 110 N/mm, then it is designed for gen4 link and should work ok with gen4 link. Going with gen5 link and aftermarket unchanged shock (for gen4), it should work ok too when using correct spring (minus 10 compared to gen4).
c) My experience with gen4 and Ohlins was: myself 85kg naked, fast pace with slicks, used gen4 Ohlins as it ships from Ohlins, tried 110, 115 and 120 spring and had very often some tearing happening (thinking maybe its normal). Did not try to fix this with different valving. Then upgraded to gen5 link together with valving recommendation from LDH and lighter spring (100, 105). Boom, now tire wear changed to prefect and tearing rarely happens (bad weather). Great return of investment if you need 20 rear tires instead 26 per season.
LDH and wheelz96 like this.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is online now
post #19 of 25 Old 05-14-2019, 09:25 AM
evallarta1's Avatar
First, it is IMPOSSIBLE to diagnose tire wear from a picture. There are so many variables that must be evaluated before any change can be made. Otherwise everything everyone is telling you is a guess. These guesses will have you chasing your tail trying to figure out a solution.
Whats your suspension settings? Preload, rate, oil level, compression, rebound?
Rake, trail, swingarm angle?
Track temps? Weather? Pace? etc.
Once you look at all the variables your can make an assessment of whats going on where to go.
Here's what a few spec sheets look like to help keep you on track.
Velocity Calibrations
evallarta1 is offline
post #20 of 25 Old 05-14-2019, 09:52 AM
LDH
LDH's Avatar
I do not remember if we used the C36 or C37 Valve spec. Do you recall?
LDH is offline
Michelin Slicks..good or bad johnnyb-21 Race and Stunt 7 05-09-2006 07:24 PM
FS: Dunlop 208 GPA's & KR106 Racing Slicks mikdivad Parts, Gear and Accessories 2 08-28-2005 10:16 PM
Iím ditching the race dots for slicks! zrxhooligan Performance and Tech 15 07-29-2005 11:45 PM
Michelin Pilot race Scuffs and Grooved Slicks Gixx1300R Parts, Gear and Accessories 4 07-10-2004 01:59 PM
Which slicks? chicken The ZX-10R 1 05-03-2004 09:21 AM
