Questions about a Gen 2 Busa shock on a gen 2 ZX10. - Kawasaki ZX-10R.net
post #1 of 6 Old 12-29-2015, 09:32 PM Thread Starter
Xx_Godzilla_xX's Avatar
Ok I've read as much as i could find.
So far the ONLY questions i have are.
1. I've read some use the zx14 spring? Is this on the busa or zx10 shock?
2. I know somebody with a gen 2 busa shock with a zx14 spring.
Would this be more stiff than a busa spring on a busa shock?
Thanks
Werkes GP exhaust, De-cat, power commander 3, quickshifter, secondary butterflies removed, -1 front + 2 rear sprocket, ape cam chain tensioner, core moto brake lines, 1/5th throttle insert, pair valve block off, speedodrd, Techspec tank grips, servo eliminator, k&n air filter, Kawasaki oil filter, EBC clutch plates, CRG RC2 levers
Xx_Godzilla_xX is offline
post #2 of 6 Old 12-30-2015, 12:38 AM Thread Starter
After more searching I've found the busa spring is stiffer than the zx14.
Busa 14.5kg/mm
ZX14 9.7kg/mm
The busa would be better for me. According to racetech's calculations.
post #3 of 6 Old 12-30-2015, 08:27 AM
Bottoms-Up's Avatar
Why not just buy the right spring for your weight from Racetech
and respring the 10's shock?
Bottoms-Up is online now
post #4 of 6 Old 12-30-2015, 09:52 AM
gazx10's Avatar
ran a busa shock on the 07 10. worked ok, heavy shock.
gazx10 is offline
post #5 of 6 Old 12-30-2015, 10:01 AM
zx racer's Avatar
I have a gen2 busa shock on my gen1 it is stiffer but works good for me.
05 ZX-10R SWB.
zx racer is offline
post #6 of 6 Old 12-30-2015, 11:57 AM Thread Starter
Entering my weight on racetech.
Says i need a 12.196kg/mm
Im thinking after lowering and stretching +6" it should be in the right range with 14.5kg/mm.
gen 2 busa shock mixedboitoo Wanted: Buy or Trade 1 11-05-2013 12:43 PM
F/S: gen 1 busa shock Jbundrick Parts, Gear and Accessories 2 10-21-2013 06:27 PM
2nd Gen with Busa shock Bmore-stunter Suspension and Tire Tech 2 05-06-2012 10:05 AM
first gen busa shock crowbar Parts, Gear and Accessories 0 03-19-2012 09:57 PM
Gen 2: 07 Busa Shock on Gen 2 ZX10 alvinhickman Performance and Tech 5 02-25-2012 08:22 PM
