Q3 tyre pressure? - Kawasaki ZX-10R.net
post #1 of 19 Old 12-16-2013, 02:44 AM Thread Starter
Q3 tyre pressure?
How u all going ? What tyre press are u all running on the q3 for fast road riding? I have been using sportsmarts and they are best run at low psi .very stiff tyre anyway i got the q3 to to see how it compares with the spoortsmart the sportsmart is the best tyre I've used bye a fair bit in terms of stability. grip.tip in. and longetivity hopefully the q3 is as good .
shakey is offline
post #2 of 19 Old 12-16-2013, 03:43 AM
-AK-'s Avatar
34 front 36 rear.
I was suggested I could drop 2 psi but I still prefer the above
Track 30 cold front 28 rear
Gen4 2013 White and black
Mod's to be done
  • PCV
  • Rear Shock upgrade.
-AK- is offline
post #3 of 19 Old 12-16-2013, 04:02 AM Thread Starter
cheers ak
shakey is offline
post #4 of 19 Old 01-02-2014, 06:43 PM
Caffeine's Avatar
This is from 8541Hawk
superhawk forum member
With tire pressure the only way to get the proper pressure is to check them cold and then hot. You are looking for a 10% rise in pressure, so 40 psi cold/would be 44 psi hot, as an example.
If you get more than a 10% rise, you are overheating the tires and wearing them out at a very fast rate for no real gain.
If you have a less than 10% rise you will not get the traction the tire is capable of producing.
Also if you tend to run higher pressures (on the street) you also tend to get longer tire life.
I bought a key chain pressure monitor so I didn't have to measure cold.. jump off when hot and measure quick.. PITA! but that's your call.. You will also find different tires heat differently and morning to afternoon changes temp again.. it's an art not a science.. I supose nitrogen may help in this situation..
zx10r
man. says front/ rear 36/42.. starting point.
Can't find the one I bought.. didn't pay nearly this price.. but to give you an idea
http://www.tpms.ca/MOTO-TRACK-2-PURC...FVBgMgodrgkAHg
Caffeine is offline
post #5 of 19 Old 01-02-2014, 08:03 PM
TheLastViking's Avatar
Run the pressure that puts the rubber at 145F. Pressure don't mean shit.
TheLastViking is offline
post #6 of 19 Old 01-03-2014, 07:43 PM Thread Starter
I find the dunlops like lower psi 32 f 32r or even a touch lower especially the sportsmarts very stiff tyre and also depends on what riding u are doing .
shakey is offline
post #7 of 19 Old 01-03-2014, 07:45 PM
The Pace
scout's Avatar
Unlike the powers I find the q3's don't care what's in them. 30/30 but if I put more or less simply doesn't matter. This is why I like them. Second remaining reason is that the front V's slower than powers.
scout is offline
post #8 of 19 Old 01-04-2014, 09:00 AM
Post Whore
Older Guy's Avatar
30 rear, 31 front....worked with the Q-2's and also with my new Q-3's....ran on the track and was fine....
Older Guy is offline
post #9 of 19 Old 01-04-2014, 09:58 AM
TechX's Avatar
30-28 hot off the warmers for track day as given to me by the Dunlop Rep. Street use 32 34 cold.
TechX is offline
post #10 of 19 Old 01-04-2014, 11:44 AM
or10r's Avatar
O.G. and Tech, what cold pressure did you start with?
or10r is offline
q3 tyre pressure? shakey Suspension and Tire Tech 0 12-16-2013 02:43 AM
Tyre pressure Phenolics Suspension and Tire Tech 16 11-14-2012 05:13 AM
More tire (tyre) pressure advice SoCal90 Performance and Tech 3 11-09-2007 12:02 PM
tyre pressure for race wets...... grunty-motor Track 4 10-08-2007 03:13 PM
tyre pressure for the track? Marko Rossi Performance and Tech 8 05-03-2006 05:45 AM
