psi in pirelli superbike pro tires. - Kawasaki ZX-10R.net
post #1 of 5 Old 08-06-2012, 10:34 AM Thread Starter
ROACH's Avatar
What psi you guys running in these things? I'm about to throw my first set on and wouldn't mind a head start on fine tuning psi's. track is abrasive and around 100 degrees. Thanks!
ROACH is offline
post #2 of 5 Old 08-06-2012, 12:50 PM
Felix el gato's Avatar
Images: 139
Baseline: COLD: front: 29........rear: 25
HOT: front: 32 .......rear: 27
My routine: check psi before putting on warmers....check again after 35-40 mns
on warmers, check again right after 1st session.
Check again 'round 11 am when track is warmer...
Some excellent info here ---> http://www.diabloracer.com/phpBB3/index.php
'06 green ZX-10R Race / '05 orangina ZX-10R track
Wera West Expert #95
______________________________________________
Felix el gato is offline
post #3 of 5 Old 08-06-2012, 01:32 PM
Always On Mod
Animal11's Avatar
Cold: 29 front, 27 rear
Never checked them hot, I had the tire guy check them hot once and he said they were good, so I never checked again, my wear looked beautiful so I didn't worry or make changes
Running buttonwillow, which is hard on tires and 100+ air temps during the day
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #4 of 5 Old 09-10-2012, 05:04 AM
Slick pro tire pressures
I run in hot weather (Middle east, Bahrain GP and Losail GP track), 27 front and 24-25 rear cold. I fluctuate from 26-28 front, and 22-25 rear cold, which gives me a 31psi front and 28 psi rear.
I find that when the front is less than 31/30 psi I get a squidgy feeling on turn in, just before I reach full lean, sometimes the bike leans to almost full lean angle, and then drops suddenly again, its like the bike is leaned over, but the contact patch is not on the edge of the tire, (as the carcass is too flexible), then the contact patch slips and shifts.....
I cure this with a bit more pressure in the front, 32psi when hot.
The rear works well with 28psi hot, any more and i loose traction.
The ideal pressure depends on the track temps and how abrasive the track is.
Also a little bit on personal feel, ie do you like a squidgy turn in with more grip, or a sharper turn in while sarafising grip.
Tire temps/pressures should be taken always when the tires are hot, ie off the track or at least off the warmers, tire pressure when tires are cold is very vague, and will vary alot depending on the track temperature.
Bashir is offline
post #5 of 5 Old 09-16-2012, 12:59 AM
gixr2zixr's Avatar
Try the SBK/SC2 front with the Pro Slick rear....best combo
Cold Rear 23
Cold Front 29
Hot Rear betwen 25 and 28
Hot Front between 31 and 34
gixr2zixr is offline
Pirelli Angel tires.. Anyone use them?? Uncle Bob The ZX-10R 25 11-20-2011 02:20 PM
Trying out Pirelli Diablo Superbike Pros anaxdlere The ZX-10R 11 05-26-2011 05:31 AM
Pirelli Diablo Superbike PRO Slick tires Colinr_69 General Motorcycle Discussions 4 02-19-2011 10:39 AM
Pirelli tires zx-10-devil Vendors deals 4 06-25-2007 12:00 PM
Price for Pirelli tires thedoctor Vendors deals 2 05-01-2007 11:46 AM
