>> Powder Coating Rims << - Kawasaki ZX-10R.net
 3Likes
  • 1 Post By SkyDork
  • 2 Post By or10r
post #1 of 7 Old 09-29-2018, 02:09 AM Thread Starter
Melampus's Avatar
Question >> Powder Coating Rims <<
I'm considering powder coating OEM rims, and I was told today that the powder [coat] is relatively heavy. Is there any merit to this claim? How much weight could honestly be added per rim by powdercoating them.?!
https://www.eastwood.com/eastwood-extreme-chrome-bonded-powder.html?SRCCODE=PLA00020&msclkid=6ca8996f72d71 9ddd1aac2c058c2dbf8
Embracing the silence amid a life & land full of static...
Melampus is offline
post #2 of 7 Old 10-01-2018, 03:36 AM
or10r's Avatar
I would pm Herb and ask. He is the man around these parts.
https://www.zx-10r.net/forum/member.php?u=3592
or10r is offline
post #3 of 7 Old 10-01-2018, 07:31 AM
ddipaola's Avatar
I've seen plenty of powder coated, painted, plasti-dipped, etc. rims at the track. I can't imagine it adds anything more than a few ounces.
If you want it, get it! Shouldn't be too expensive either.
When in doubt... send it!
ddipaola is offline
post #4 of 7 Old 10-01-2018, 08:20 AM
SkyDork's Avatar
Powder coating is the best way to go - for durability. If you're trying to match a specific color, you should stick to paint. If you're worried about weight, stick to paint. If you want the cheapest, easiest way to go, stick to paint. All that said, powder coat those donuts!
The weight difference will depend on the technique used. Obviously, if you're painting over the wheels and use multiple coats of it, the weight advantage will be minimal at best. If you strip the rims, repaint them, then you'll save several 10s of grams in weight versus powder. Woohoo! Powder will be a bit heavier, but not enough to worry about IMO. Unless you're peterd10r, then don't stress about it.
The powder will cost more than paint though. Not in terms of the material, but you have to pull and replace the wheel bearings. You can mask off and paint over/around the current ones, but that's not an option for powder. So the cost goes up in terms of that.
or10r has your contact info for all that stuff! Herb will get you squared away on it!
TheRoadWarrior likes this.
#WordCrimes
SkyDork is offline
post #5 of 7 Old 10-02-2018, 03:30 AM
or10r's Avatar
If your REALLY worried about weight then strip the paint off and polish them for that fresh from the 90's look.
SkyDork and michael4012 like this.
or10r is offline
post #6 of 7 Old 10-04-2018, 04:13 AM Thread Starter
Melampus's Avatar
Arrow
or10r <> PM sent. Thank you! As for polishing them, I live about 2 hours South of you, on the East Coast, so polishing would require repolishing every 2 months, and with the humid salt air down here, a chrome dip would pit in 6 months. Powder coating seems to be a no-brainer...
ddipaola <> Personally, I can't possibly imagine that the amount of powder that would take to coat a rim could possibly amount to enough weight to mention, but like I said in my post - someone local said it did so I figured I owed myself some cursory research to confirm or deny.
As for my wanting it, man... I don't know whose bike this is I found in an image search, but I fell head over heels with this linked scheme. I have been piecing together an ex-track Gen1, and after buying raw white Chinese fairings (1 of which that has already broken a tab ), I really like the look of white. I started talking paint with 97GRNRS; then I started researching Pearlescent White Gen1's; and I found a scheme that hits the nail right on the head, for me. Thing is, I think the chrome rims make it... I think black rims would be too much contrast.
https://www.zx-10r.net/gallery/displa...p?imageid=1201
...but like I said to or10r, polished & chrome are out, and I found a "chrome" powder coat that looks awesome. A good buddy of mine that's been spinning wrenches on Kawis since the mid 80's has a local guy that he thinks will PC a [stripped] rim for me @$40/$50 each. I assume I'd pay a premium for this "chrome" powder I found, but it still seems worth it if it looks like chrome... & w/o the maintenance! I'm on a budget, and thus, moving slowly on this project. I'm 10 months in on the refresh now, but I like to get my ducks in a row so I only have to do everything once.
Actually, I've been researching intergenerational rim exchangeability to see if I can pick up a lighter pair of OEM shoes to be the ones I have powder coated so my bike's never down, and then sell off my stockers to recoup my later model OEM rim buy in. SKYDORK, is the only one whom has helped me out on that research, and he believes I can swap up to a Gen3 on my Gen1. He thinks the rear is plug & play while the front requires different bearings & spacers. My hang up now, with that, is I can't determine the raw weight savings of Gen1 rims vs. Gen3 rims bc no matter how many Google search cues I use, I just can't find those raw weights.
SKY-D <> As always, thank you for your input, and as stated above, I'm leaning towards the PC because if I do the Pearlescent White, I really want a "chrome" look on the wheels. I think OEM black rims will dull the brightness the white fairings create, and I think matching white wheels would be straight ghetto. I'm really into the contrast of the black lower against chrome shoes with the continuity of the black rubber to pull it together.
As for weight, I'm not stressing 10's of grams in paint. I'm only interested in the effort & cost required in sourcing Gen3 rims if I can save half-a-pound each rim. Anything less than that, I think it's just not worth the effort?
Melampus is offline
post #7 of 7 Old 10-06-2018, 08:44 PM Thread Starter
Melampus's Avatar
Heads up for anyone whom gives a sh!t, HERB, was kind enough to extend his expert opinion.
  • The PC weighs no more than paint.
  • The "CHROME" PC never looks like chrome due to a requisite clear coat that goes on after. He said it ends up looking like a "bright silver".
Melampus is offline
WTB 06 07 Engine / motor <<<<<<<<< NMBR1SPT Wanted: Buy or Trade 6 09-14-2013 06:55 PM
>>>>>2008 zx-10r - $6,300<<<<<< swing lo Bikes 4 Sale 12 07-14-2010 11:16 PM
Fellow ZX10 family... Need your support<<<<<<<<<<<< nbrion1 The Out House 25 01-22-2010 07:25 AM
