pirelli slick tear help - Kawasaki ZX-10R.net
 1Likes
post #1 of 21 Old 06-05-2015, 04:20 PM Thread Starter
Always On Mod
Animal11's Avatar
Hey gurus, I need some advice please.
Running a Pirelli SC2 slick. **Edit: its a 200/60 on my '11 zx-10R. Ohlins rear shock, Kyle link.
heat cycle 1: from fresh mount 15 laps in 3 sessions, 28 psi hot, 2:02 to 1:59's at Thunderhill wear looks good
heat cycle 2: 7 laps at 60 psi (had the tire mounted to a new wheel and forgot to set the pressure: rookie mistake) surface was melting off, then 14 laps at 28 psi hot, 1:59-1:57 lap times, wear looks good
heat cycle 3: 10-12 laps, 28 psi hot, unknown lap times but probably 1:59 to 1:57, notice the tear and assume its a cold tear
- drop to 27 psi hot, run 6/8 laps, still see the tear
- drop to 26 psi hot, run 6/8 laps, not getting any better, I took all the attached pics at this point. Turn 6 is the fast acceleration left hander, and I felt the rear spin and grip in repeated sequence
- work on smoother throttle application to not punish the tire out of the corner, but at this point the wear dots are gone and the damage is done. Thunderhill is super hard on the left side. The uneven wear grooves make me think it's a geometry/suspension induced tear? Is it a hot tear because I can't get a fingernail under the peal?
SO, did I just use up the tire and that's what happens when you run this pace with them? Do I need to switch to the SC1? Is there something about my suspension that needs to change?
Thanks
ID:	327458   Click image for larger version
ID:	327466   Click image for larger version
ID:	327474   Click image for larger version
ID:	327482   Click image for larger version
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #2 of 21 Old 06-05-2015, 06:41 PM
evallarta1's Avatar
There are soooo many variables that need to be answered to troubleshoot your problem. But lets see if we can narrow it down.
You mentioned in the beginning you were running sub 2 min laps and didnt have a problem. The first thing that comes to mind is what was the ambient/track temp when the tires didnt tear vs when they did? If there was a drastic change temp throughout the day this could be your issue and pressure wasn't set for the conditions. Also when you came off the track how did warm/cold did the tires feel?
Velocity Calibrations
evallarta1 is offline
post #3 of 21 Old 06-05-2015, 07:03 PM Thread Starter
Always On Mod
Animal11's Avatar
I figured it was a bit of a crapshoot, but can't hurt to ask right?
ambient temp on Sun was 90-95, not sure on the track temp. I was running 1:57-1:59 and didn't see any unusual wear. Other than the melting when I raced on it for 6 laps inflated to 60 psi.
Yesterday ambient temp was 90F, and I would guess the track temp was the same.
Both days the tires felt hot coming off the track, but not burn you hot, I'd guess somewhere between 160-180F. 140F I can hold my hand on all day, tires were hotter than that. I know that;s not super useful data and I should get a tire probe for the future.
Animal11 is offline
post #4 of 21 Old 06-05-2015, 07:09 PM
evallarta1's Avatar
Was 90-95 from your first session to the last? Or did the temp raise as the day went on? Also was it sunny?
If they weren't super hot it sounds like your pressures were probably off. We run the DOTs at 24.5 to 25.5 with good results.
post #5 of 21 Old 06-05-2015, 07:23 PM Thread Starter
Always On Mod
Animal11's Avatar
Sunday 90-95 was the peak ambient temp. The morning started out cooler, maybe around 75? and got hotter as the day went on. It was partly overcast.
Yesterday the peak ambient temp was 90. It seemed to get hotter earlier in the day compared to Sunday and it was sunny all day.
I'm going off memory here, and I generally don't pay attention to the weather too much. Sounds like I need to start doing a better job of that.
Animal11 is offline
post #6 of 21 Old 06-05-2015, 08:06 PM
evallarta1's Avatar
Yup, sounds like that's probably your issue. At 75 your pressures were probably good, but as it got warmer those pressures weren't correct. We've seen swings in temps so much here in the midwest that in the morning 1 compound is need and then you have to switch to another in the afternoon.
post #7 of 21 Old 06-05-2015, 09:29 PM Thread Starter
Always On Mod
Animal11's Avatar
So you're saying I should switch to the SC1? Thanks for talking things through with me. I appreciate it.
Animal11 is offline
post #8 of 21 Old 06-05-2015, 10:15 PM
I dunno that's an odd wear pattern. Almost pressure related looking or maybe a rebound too slow by the rhythmic pattern. What did you run the pressure at?
Mod list: GP 25mm front cartridge kit / JRi piggyback triple shock / attack rear link / Brembo RCS / Galfer SBK lines / Austin Racing GP2r / BMC Race Filter / Yosh Case Savers / Vortex Clip ons / Vortex Rear sets / Vortex Keyless Gas Cap / Lighttech Chain adjusters w/ Fast Frank Quick change / AIM solo DL data logger / motion pro throttle / KIT ecu & Harness / Moto XP Ricambi Bodywork / Puig Double Bubble /
J_fuggin_t is offline
post #9 of 21 Old 06-05-2015, 10:49 PM Thread Starter
Always On Mod
Animal11's Avatar
28, then 27, then 26
Animal11 is offline
post #10 of 21 Old 06-06-2015, 05:04 AM
caboose's Avatar
Send a message via MSN to caboose
Well, 60+ laps is a lot of laps on a liter bike.
The wavy look to the tear pattern makes me think it's a suspension issue (rebound too slow? spring too soft?) but with 60+ laps on that tire grip will be falling off so it's not working properly.
2010 10R Superbike
caboose is offline
hot tear or cold tear plasticbaby The ZX-10R 26 09-05-2014 05:47 AM
Pirelli will supply 17" slick to WSBK Fred-R Race and Stunt 1 11-15-2011 05:15 PM
Pirelli Diablo Superbike PRO Slick tires Colinr_69 General Motorcycle Discussions 4 02-19-2011 10:39 AM
ZX10R Puttin the hurt on a Pirelli Slick M.Guenette Pictures and Videos 3 02-08-2011 09:28 PM
Drag slick or flat slick focalf5 Strip 17 02-28-2008 09:09 PM
