Oil soaked tire - Kawasaki ZX-10R.net
post #1 of 22 Old 01-13-2013, 07:03 AM Thread Starter
Tx 04 ten's Avatar
Oil soaked tire
Long story short, I blew my motor a few months back and when it went it shot a whole in the lower case and sprayed oil everywhere including my rear tire. Is there a certain cleaner such as brake parts cleaner or a certain degreaser that anyone has used that would work well on the tire? Also is it possible that beings the oil stayed on the rear tire for so long that that it might not grip as good as before even after I clean it? I'm running they old school pp's... Thanks
Tx 04 ten is offline
post #2 of 22 Old 01-13-2013, 08:23 AM
Bam Bam's Avatar
scrap it its not worth the risk for $250 oil soaks into rubber you will never get it out
2011, guhl flash and tune,k&N race spec,Graves ti. 3/4 slipon,1/5 turn insert,-1+2 sprockets,tech spec tank pads,hotbodies venom windscreen,T-rex racing fork and frame sliders, 55w hids,Ivans block off plates,Black Pro bolt kit, Speigler braided brake lines, Mikey Moto lightweight rear rotor.CRG RC2 shorty levers, Suspension Technologies reworked shock
Bam Bam is offline
post #3 of 22 Old 01-13-2013, 08:44 AM
mrbzx7's Avatar
Man I busted my oil pan and oil soaked my tire. I just used a whole can of brake cleaner on it and did a lil burn out and that tire snapped right back! I wouldn't get rid of it if it were me.
Andrews Motorsports
2009 ZX10R aka "The General"
2008 ZX14R coming soon!
Paypal [email protected]
mrbzx7 is offline
post #4 of 22 Old 01-13-2013, 09:09 AM
jowek70's Avatar
If i was putting $ into a new engine, I would not cheap out on $200 worth of rubber.
jowek70 is offline
post #5 of 22 Old 01-13-2013, 09:39 AM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
Get a couple cans of cheap carb cleaner from the auto parts store.
It will get all oil off the tire.
I use it to clean my paint guns, hands, any metal etc...
hellsrazor is offline
post #6 of 22 Old 01-13-2013, 10:19 AM
jdub669's Avatar
Brake cleaner eats rubber/ plastics and carb cleaner is even more aggressive. I wouldn't use either on a tire... if it was me I'd probably pressure wash it with a detergent and then do a quick burn out.
Sent from my SAMSUNG-SGH-I717 using Motorcycle.com Free App
"mechanical engineers build weapons, civil engineers build targets"
jdub669 is offline
post #7 of 22 Old 01-13-2013, 10:25 AM
hellsrazor's Avatar
Images: 23
Well, it has not hurt the plastic cup that holds the paint or the rubber O rings
in my paint guns.
Just sayin
post #8 of 22 Old 01-13-2013, 10:34 AM
jdub669's Avatar
Your putting a petroleum solvent on a petroleum based product..
jdub669 is offline
post #9 of 22 Old 01-13-2013, 10:39 AM
mrbzx7's Avatar
Water and oil dont mix so high pressure water I think would just move the oil around, carb/brake cleaner will cut the oil. Kinda like how dish soap cuts grease
Andrews Motorsports
mrbzx7 is offline
post #10 of 22 Old 01-13-2013, 10:41 AM
jdub669's Avatar
Did I not say pressure wash with a detergent?
jdub669 is offline
Heat Soaked Or Clutch Issues? Spillman Performance and Tech 7 09-10-2008 08:33 AM
Tires soaked in oil.... ram360 General Motorcycle Discussions 13 04-09-2008 11:08 PM
Tire Review: Dunlop N-Tec DOT rear race tire wsmc27 Track 4 08-09-2007 03:14 PM
Monting rear tire without tire machine? blackisfaster Performance and Tech 9 04-24-2007 01:28 PM
