Ohlins v Elka - Kawasaki ZX-10R.net
 1Likes
post #1 of 31 Old 02-03-2013, 12:04 AM Thread Starter
Ohlins v Elka
Hey guys trying to decide what shock to get. It seems there are a few run out sales of older ohlins shocks for the gen 1 model KA345. However I can get a 3 way elka for not much more. Just after some opinions from people that have used these shocks for street and occasional track use. Leaning toward the Elka as I know the company will take the time to set it up for me. Any help would be much appreciated.
nude10r is offline
post #2 of 31 Old 02-03-2013, 12:37 AM
SubDude's Avatar
I like my Elke on my Gen 1 but, if the ohlins is actually cheaper, I'd probably go with that simply because of their reputation as a higher quality shock? For some reason, the rear end of my bike liked a low ride height with my Elke. I even pulled the ride height washer out of the top shock mount to give me more range of negative adjustment. I put the front forks flush with the triples too. The gen1 is already a short bike with a steep front end rake. If you mess with too much rear ride height adjustment on these aftermarket shocks and lower the front, the bike feels like it's understeering and going to tuck the front end.
One thing that I do like about the Elke is the easy preload adjustment. You just stick an allen wrench in the holes and turn it. There's a thrust bearing between the spring an the adjustment collar that make it super easy to turn. No lock ring or anything. The ohlins might be different?
Here's a pic. The red and gold anodizing really stand out.
SubDude is offline
post #3 of 31 Old 02-03-2013, 03:35 AM Thread Starter
would you say the bike is a lot better over sharp bumps? I imagine that it's miles better than stock but the roads around me have a lot of washboard style bumps which suck with the standard rear. My re-sprung re-valved forks handle it well and that's the sort of improvement I'm hoping for.
nude10r is offline
post #4 of 31 Old 02-03-2013, 04:50 AM
SBK X's Avatar
How one or the other soaks up bumps has more to do with how you set them up, it's not an indication of quality.
Both are more than adjustable enough.
If your talking the same price between the two, or the Ohlins being cheaper, than I see it as a no brainer, Ohlins all the way!
Ohlins don't sponsor people yet nearly every top end competitive team run there products by choice, says allot to me.
LDH likes this.
SBK X is offline
post #5 of 31 Old 02-03-2013, 08:22 AM
ZX10BURNER's Avatar
Send a message via Yahoo to ZX10BURNER
Both shocks are quality items and you really can't go wrong with either. Price difference aside one of the biggest differences is the support you can get with Ohlins. Ohlins has a much larger knowledge base to draw from for set-up, service, and support. If you plan on track days or racing you'll find more set-up information for the 10R with Ohlins at specific tracks, tires etc.
I've run Ohlins on my bikes for years; have the 46 PRXLS on my 04 10R along with the 25mm kit, both items perform very well. Honestly purchase the one that is more cost effective for you and which shock/dealer offers the support you may need for set-up/service and least amount of down time.
It's Not denial, I'm just very selective about the reality I accept.
ZX10BURNER is offline
post #6 of 31 Old 02-03-2013, 03:12 PM
Dragone's Avatar
Images: 11
agreed, that both shock choices are of quality. I also think that both companies offer great support. Don't forget about the penske line while you make your choices.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #7 of 31 Old 02-03-2013, 06:38 PM
RPG76's Avatar
Ohlins for sure!! Elka should stick to ATV's it's what they know.
05 ZX10r "the Mongrel": GP Suspension rebuilt forks, LE Penske double shock, 05-06 ZX6rr shock linkage, Brembo RCS MC, Nissin calipers (best mod for this bike!!!), Attack rearsets, Motion Pro Revolver throttle kit, ASV clutch lever, Champs sliders, smoked Zero Grav DB, Ti caliper bolts, CF fender, Renthal grips, Speedo healer, Maviryk MDA123 batt, Supersprox +3 520, That's it..... For now
190/55>190/50
RPG76 is offline
post #8 of 31 Old 02-15-2013, 05:03 PM Thread Starter
bought the ohlins will let you know how it goes. Hopefully it cures the running wide issues!
nude10r is offline
post #9 of 31 Old 02-15-2013, 05:44 PM
or10r's Avatar
Is the bike not turning on exit?
or10r is offline
post #10 of 31 Old 06-03-2013, 12:31 PM
Crescent1101's Avatar
I found this thread and wanted to revive it instead of starting a new one. Where did you find an Ohlins for cheaper than Elka? I can get a Stage 4 Elka for $760. Is there any other opinions out there for Elka? If I could get a Ohlins for cheap I would.
2009 R6 Racebike - Up for sale!!! Let me know if interested.
2013 ZX10R- SOLD
2008 ZX10R- SOLD
Crescent1101 is offline
Feeler: Elka 3way Penske Trple and Stock catrideges with ohlins 20mill kit cMac Parts, Gear and Accessories 9 10-05-2011 07:57 PM
Aftermarket Shock Selection tips...Penske Ohlins Elka hillcountry10r Performance and Tech 21 10-07-2010 09:53 AM
WTB Ohlins or Elka 3-way shock johnnyb-21 Wanted: Buy or Trade 0 03-21-2008 12:47 PM
WTB: Used Penske/Ohlins/Elka rear shock Cling Wanted: Buy or Trade 6 04-21-2007 03:14 AM
elka or ohlins? speedfreak Performance and Tech 10 04-14-2005 07:49 PM
