Ohlins TTX36 recall - Kawasaki ZX-10R.net
 4Likes
post #1 of 34 Old 04-02-2015, 09:10 AM Thread Starter
Abo7maid's Avatar
Ohlins TTX36 recall
FYI
Which TTX shock absorbers are affected? Check here!
Originally Posted by scout View Post
So, I get a plus one for at least CHECKING the oil???!!!
oh, I did have to add distilled water to the reservoir as it was empty. Thought that odd as it was over full mark when brand new
Abo7maid is offline
post #2 of 34 Old 04-05-2015, 08:42 AM
Speed-racer's Avatar
Maybe someone who sells these to us can reply and tell us exactly what was found to be the problem. Was it the "bore job", an "O" ring, a nut not tightened to spec., or the piston or valve, etc, etc.... Perhaps if you got one, and it was revalved, the "problem" has been taken care of with the revalve?????
edit: found this, http://www.bikehk.com/shop/power/Imp...utside_USA.pdf
It's not that I don't want to ride with you, but you ride too damn slow.
Speed-racer is offline
post #3 of 34 Old 04-05-2015, 10:03 AM
Pretty good Ohlins shock video https://www.youtube.com/watch?v=L8qEfGi50BQ
post #4 of 34 Old 04-05-2015, 10:31 AM
fireman69's Avatar
OK. I own 2 of these for my race bikes. How would a guy go about finding out what the model number is? I'm going to have to look into it I guess
fireman69 is offline
post #5 of 34 Old 04-05-2015, 10:53 AM
post #6 of 34 Old 04-05-2015, 10:57 AM
fireman69's Avatar
Originally Posted by Speed-racer View Post
I apologize. I missed this sentence. For anyone searching this topic.
"You can find the batch number on the shock absorber, stamped on the cylinder head, near the top
mounting point."
post #7 of 34 Old 04-05-2015, 11:37 AM
LDH
LDH's Avatar
Yes it is the Fuji Nut on the end of the shaft that needs to be checked.
It's a pretty quick procedure in spite of the fact it requires almost 100% take-down of the shock body. It is not part of the re-valve procedure we do for changing the valve spec to work with linear race linkages so even if you have had a re-valve done you will still need to send any affected units in for the service.
Your Shock Part Number (KA340X) and the Serial Number are both stamped on the head of the shock on opposite sides.
Speed-racer likes this.
LDH is offline
post #8 of 34 Old 04-05-2015, 02:12 PM
peterd10r's Avatar
Images: 7
If you google Ohlins ttxmk2 recall theres a pdf (think in Swedish)that lists all the suspect numbers
peterd10r is offline
post #9 of 34 Old 04-05-2015, 02:17 PM
peterd10r's Avatar
Images: 7
Here you go!
KA035-136126
KA035-137366
KA035 -138068
post #10 of 34 Old 04-05-2015, 02:19 PM
peterd10r's Avatar
Images: 7
Thats for 2011-2015 ZX10R sorry all
Gen 4: Ohlins TTX36 MKII Mechatronics Shock kman0066 Parts, Gear and Accessories 19 06-23-2013 10:23 PM
Wanted: ZX10 08 Ohlins TTX36 PetsuZX Wanted: Buy or Trade 0 09-26-2011 06:13 AM
Ohlins R/T forks and TTX36 shock review Feanor The ZX-10R 25 05-29-2010 11:30 PM
08 Zx-10r Ohlins Ttx36 yanacawa Performance and Tech 11 03-04-2008 06:17 PM
Ohlins TTX36 KaTooM Vendors deals 1 11-30-2007 04:47 PM
