Ohlins TTX KA931 base settings - Kawasaki ZX-10R.net
 2Likes
post #1 of 12 Old 12-28-2015, 05:41 AM Thread Starter
Greenblood7's Avatar
I am looking for information on a KA931 for a Gen 4.
I am 92kg or around 200lb in my gear, wondering what would be the base settings and the recomended spring rate for the road.
Greenblood7 is offline
post #2 of 12 Old 12-31-2015, 11:52 AM
peterd10r's Avatar
Images: 7
Green blood I will check out my KA931 booklet that came with the shock!I remember reading "base settings"but not weight based settings!I will get back to you today.
peterd10r is offline
post #3 of 12 Old 12-31-2015, 12:06 PM
LDH
LDH's Avatar
Assuming you are using the OEM linkage, 202 lbs in gear would put you right on the edge of a 115Nm spring at 30mm of Sag
Comp 10 Clicks
Reb 14 Clicks
LDH is offline
post #4 of 12 Old 12-31-2015, 12:34 PM
peterd10r's Avatar
Images: 7
Thanks LDH for clearing that up!as I said pretty sure the booklet only gives base settings!happy New Year LDH keep safe!stay happy,
Cheers
Peter
post #5 of 12 Old 12-31-2015, 12:43 PM
LDH
LDH's Avatar
Those are standard settings for compression and rebound. There is no such thing as settings based on weight alone. It is impossible to custom set up damping rates outside of a generically decent setting that would work for most average riders. If you install the correct valve spec and the damping rates are close enough then with the exception of very few individuals the one size fits all philosophy will work and it does and with an Ohlins shock especially the TTX versions very rarely will anyone actually need to deviate from those settings more than a few clicks in either direction.
I mention the above because I have seen where some suspension companies claim to custom setup the damping for each shock for the riders weight and that is just a sales gimmick at best. "Rider Weight" is just one of a myriad of variables that go into selecting a damping curve.
In contrast selecting a spring rate is mainly based on rider weight
CanyonCarver likes this.
LDH is offline
post #6 of 12 Old 12-31-2015, 07:35 PM Thread Starter
Thanks for the response guys.
post #7 of 12 Old 12-31-2015, 07:38 PM Thread Starter
Comp 10 Clicks
Reb 14 Clicks
So when you say "right on the edge of a 115Nm spring" should i go for a 120Nm or 110Nm spring?
post #8 of 12 Old 01-04-2016, 09:55 AM
LDH
LDH's Avatar
By the book at 202lb in gear you should be using a 120Nm spring. At 199lb in gear it would be a 115Nm spring so you see it is very close either way and you will either end up with a softer spring running more preload or a stiffer spring running less.
There are pros and cons to both ways and generally speaking an undersprung bike can be ridden much easier than an oversprung one, but the Gen 4 complicates this issue by having a really stiff start rate on the rising rate linkage.
In the real world if this is just a streetbike I would likely go with the 115Nm and it will be just fine. If it is a track only bike I would get one of our linear race linkages, revalve the shock to match and install a 105Nm spring.
LDH is offline
post #9 of 12 Old 01-04-2016, 04:19 PM Thread Starter
Thanks LDH, I will go with the 115Nm spring.
post #10 of 12 Old 01-04-2016, 04:28 PM
LDH
LDH's Avatar
You ever go listen to live music at The Orient or is that way too touristy for locals?
LDH is offline
Ohlins TTX Selztoad Parts, Gear and Accessories 3 03-17-2015 09:51 PM
Ohlins TTX EC tap tap Suspension and Tire Tech 9 05-01-2014 02:23 PM
Gen 4: Ohlins 30mm Cartridge Kit and Ohlins TTX Shock ThrottleAbuse Parts, Gear and Accessories 2 07-05-2013 03:59 PM
BST's Ohlins TTX 36, Ohlins FGRT 804, etc etc... tony83 Pictures and Videos 117 01-18-2010 12:39 AM
Base suspension settings for approx 200lbs kwack Performance and Tech 9 01-13-2006 04:29 AM
