I am looking for information on a KA931 for a Gen 4.
I am 92kg or around 200lb in my gear, wondering what would be the base settings and the recomended spring rate for the road.
Green blood I will check out my KA931 booklet that came with the shock!I remember reading "base settings"but not weight based settings!I will get back to you today.
Those are standard settings for compression and rebound. There is no such thing as settings based on weight alone. It is impossible to custom set up damping rates outside of a generically decent setting that would work for most average riders. If you install the correct valve spec and the damping rates are close enough then with the exception of very few individuals the one size fits all philosophy will work and it does and with an Ohlins shock especially the TTX versions very rarely will anyone actually need to deviate from those settings more than a few clicks in either direction.
I mention the above because I have seen where some suspension companies claim to custom setup the damping for each shock for the riders weight and that is just a sales gimmick at best. "Rider Weight" is just one of a myriad of variables that go into selecting a damping curve.
In contrast selecting a spring rate is mainly based on rider weight
I weight slightly more than you at around 95kg in gear. I went with the 120Nm spring as its unlikely i will ever lose weight. Stock linkages etc, i find it works really well on the street.
Related Threads
Kawasaki ZX-10R Forum
2.1M posts
128.9K members
Since 2003
