Ohlins TTX EC - Kawasaki ZX-10R.net
post #1 of 10 Old 04-06-2014, 07:39 AM Thread Starter
Ohlins TTX EC
I just picked up a Ohlins TTX EC and was wondering if anyone has put the hydraulic preload controller somewhere else than the default location? I'd like to pull off the rear pegs, since they aren't being used for anything.
tap tap is offline
post #2 of 10 Old 04-06-2014, 07:48 AM
dude's Avatar
Can't you use the sub frame after you remove the pegs? :)
Sent from Motorcycle.com App
dude is offline
post #3 of 10 Old 04-06-2014, 07:52 AM
Baddie's Avatar
Have A look where this one installed (under seat).
Which I like.
http://www.untamedvelocity.com/2011%...ke%20build.htm
Baddie is offline
post #4 of 10 Old 04-06-2014, 09:01 AM
alang's Avatar
zx10 mods
thanks for sharing your zx setup
alang is offline
post #5 of 10 Old 04-07-2014, 06:49 AM
peterd10r's Avatar
Images: 7
[IMG][/IMG]you can make a aluminum L shaped bracket and mount it too the 6mm bolt holding the rear hugger on then drill a 8mm hole in the L bracket to mount your ttx 36 bracket on too, use a alloy polish to clean up brackets and they look trick
peterd10r is offline
post #6 of 10 Old 04-07-2014, 10:30 AM Thread Starter
Thanks for the posts! I liked the under the seat idea and decided to do it yesterday. As you can see I used a zip tie to just hold it in place. Is a wire tie sufficient or do I need to secure it down with a bracket?
tap tap is offline
post #7 of 10 Old 04-08-2014, 11:12 PM
peterd10r's Avatar
Images: 7
That under seat idea is brilliant
post #8 of 10 Old 04-08-2014, 11:19 PM
peterd10r's Avatar
Images: 7
Putting the preload under seat very very clever
post #9 of 10 Old 04-09-2014, 12:10 AM
i just bolt it to the other side
-=1000rrK5=- is offline
post #10 of 10 Old 05-01-2014, 02:23 PM
Mine is on the exhaust mount.
TomLSTD is offline
Gen 4: Ohlins 30mm Cartridge Kit and Ohlins TTX Shock ThrottleAbuse Parts, Gear and Accessories 2 07-05-2013 03:59 PM
Gen 1: Ohlins TTX KA345 cajshay Wanted: Buy or Trade 0 08-12-2011 06:47 AM
Gen 4: K-tech vs Ohlins ttx. Ninja187 Performance and Tech 0 05-07-2011 11:59 PM
BST's Ohlins TTX 36, Ohlins FGRT 804, etc etc... tony83 Pictures and Videos 117 01-18-2010 12:39 AM
Ohlins TTx on a '04-'05 . Anyone tried that ?? Sto Performance and Tech 0 09-29-2008 06:15 AM
