Ohlins rear shock has small crack in body..help!!! - Kawasaki ZX-10R.net
post #1 of 15 Old 03-26-2013, 09:32 AM Thread Starter
Zx10 Lover!
Fatherdom's Avatar
Send a message via AIM to Fatherdom
Fellow riders I need ur input/ suggestion I was at thunder hill on march 18 . While there I had my suspension adjusted. While doing so we noticed small amount of oil seeping from the top/head area of my ohlins shock not the gold part but the actual head/ body part . Where do I go ? Who do I call . And is this normal? It seems to me to be a parts failure on the part of ohlins I didn't wreck and shock was never banged or dropped nothing so I don't see how this could happen. Is anyone familiar with this situation ?.
Fatherdom is offline
post #2 of 15 Old 03-26-2013, 10:13 AM
fireman69's Avatar
Can you see a crack? If so you will need to send it in to have it completely rebuilt. I had this happen on another brand before. Unfortunately I bought it that way from a member on this site.
It was junk at that point. Nobody was able to fix it. However that is the beauty of ohlis. There are hundreds of techs ou there that han help you out and parts tend to be readily avail.
Good luck
fireman69 is offline
post #3 of 15 Old 03-26-2013, 11:02 AM Thread Starter
Zx10 Lover!
Fatherdom's Avatar
Ok cool thank you so much for the info!!!..
post #4 of 15 Old 03-26-2013, 11:02 AM Thread Starter
Zx10 Lover!
Fatherdom's Avatar
One th
post #5 of 15 Old 03-26-2013, 11:04 AM Thread Starter
Zx10 Lover!
Fatherdom's Avatar
Question where do I send it ?..
post #6 of 15 Old 03-26-2013, 11:23 AM
evallarta1's Avatar
The easiest answer is send it to OhlinsUSA. They can replace any of the parts very easily. Otherwise any suspension shop should be able to fix it for you.
As to it being normal not really. But remember seals and o-rings are a wear part, so if you havent had it inspected/serviced it could happen. Also make sure it's coming from the shock and not from something else.
Velocity Calibrations
evallarta1 is offline
post #7 of 15 Old 03-26-2013, 11:27 AM
kman0066's Avatar
This guy does great work on Ohlins stuff for me.
http://www.thermosman.com/
Buy yeah, any suspension tech can probably fix it for you.
WERA Expert #43
2012 WERA National Challenge Series Open Superstock Novice Champion
http://maps.wera.com/racers/racerpro...30532136163864
COMET RACING LEATHERS
2011 ZX-10R Race bike (Vortex, Silkolene, Leatt, Yoshimura, BRIDGESTONE)
2013 ZX-6R 636 Race bike
2008 Ducati Hypermotard 1100s
kman0066 is offline
post #8 of 15 Old 03-26-2013, 11:34 AM Thread Starter
Zx10 Lover!
Fatherdom's Avatar
Right on!!!!..peace and blessing !!!
post #9 of 15 Old 03-26-2013, 01:54 PM Thread Starter
Zx10 Lover!
Fatherdom's Avatar
Questions for all who are will to offer info ..I contact a shop and ask if they worked on/ service and repair ohlins rear shock . I told him that the body of the shock had a hairline crack in it. He told me he could weld it / drill two holes into body and take at touch to it and seal it . Is this a good idea/ safe ?Or better to have the part replaced..
post #10 of 15 Old 03-26-2013, 02:29 PM
Ninja187's Avatar
Dan Kyle is in your neck of the woods. http://www.kyleusa.com/ give him a call and see what he suggests.
GEN 4: Brembo HP calipers, Brembo HP T-Drive Rotors, Brembo RCS master cylinder, Fren Tubo SS lines, re-valved Ohlins damper, Ohlins TTX shock, Yoshimura case covers/frame sliders, Yoshimura 3/4 R77D Ti exhaust, BMC filter, Puig DB, Renthal Clip ons/sprockets, attack rearsets, Guhl flash, kawi kit throttle, Ballistic EVO2 8 cell, Annitori RL quick shifter, Dunlop rubber.
Ninja187 is offline
Gen 3: Ohlins Rear Shock kneedrgn04zx10 Parts, Gear and Accessories 3 12-29-2011 11:48 AM
04-07 Ohlins Rear shock. WSMC712 Parts, Gear and Accessories 7 11-28-2008 10:18 AM
ohlins or wp rear shock rroobb Race and Stunt 9 03-09-2007 01:03 AM
ohlins rear shock rroobb Performance and Tech 0 03-02-2007 03:10 PM
Ohlins Damper/Ohlins Rear shock 04-05 HKMP7 Parts, Gear and Accessories 7 04-06-2006 12:28 PM
