Nitrogen filled ZX10R tires? - Kawasaki ZX-10R.net
 1Likes
post #1 of 77 Old 05-09-2013, 06:44 AM Thread Starter
jeffreywjones@charter.net's Avatar
I have recently switched to nitrogen in filling the tires of my car. Can I do the same for my ZX10? I can't think of a reason why it would be bad but I thought I would run it by the collective first.
Thanks in advance,
Jeff
post #2 of 77 Old 05-09-2013, 06:55 AM
whans1980's Avatar
Thanks in advance,
Jeff
DONT DO IT..... I run a tire shop and one of the benefits of the nitrogen is the tire run cooler.. on a motorcycle you want the tires to run hot so they stick.. the tires will take much much longer to warm up and they will not get as hot as they do now so you will get less traction.......
whans1980 is offline
post #3 of 77 Old 05-09-2013, 07:01 AM Thread Starter
Thanks! I didn't know that Nitrogen runs cooler than air.
post #4 of 77 Old 05-09-2013, 07:04 AM
-AK-'s Avatar
I would also think it would be to expensive if you use your bike for road and track with different pressures.
-AK- is offline
post #5 of 77 Old 05-09-2013, 07:09 AM
whans1980's Avatar
No prob man.. we used to sell the nitrogen service at my shop and we found that the guys with soft tires on high performance cars hated the nitrogen. One guy had a corvette and ran very soft tires and he didnt drive the car much.. so he said when the car sits without driving it for a couple weeks at a time the car would vibrate for about a mile till the tires warmed up cause there were flat spots in the tires from sitting.. after we switched his car to nitrogen he said the car would vibrate for about ten miles.... this was happening because the nitrogen makes the tires run much much cooler....
post #6 of 77 Old 05-09-2013, 07:12 AM
Nittany_Airman's Avatar
So, I'm going to need the science on the nitrogen runs cooler claim. The reason for the use of nitrogen is because it's density does not change as much as air with changes in temperature. If your observation is that tire pressures don't increase as much with nitrogen filled tires after warming them up, then that is why. I'm not saying you're wrong. But your claim doesn't make any sense to me.
ddipaola likes this.
Nittany_Airman is offline
post #7 of 77 Old 05-09-2013, 07:12 AM Thread Starter
It makes sense.
My 10R "wakes up" as I get into a ride. Makes sense the tires would also need to come up to temp. BTW, what pressures do you run on the street? Do you stick to the book or have you deviated? If so, why?
Jeff
post #8 of 77 Old 05-09-2013, 07:16 AM
whans1980's Avatar
http://www.wellworthproducts.com/art...rogentires.asp
post #9 of 77 Old 05-09-2013, 07:18 AM
whans1980's Avatar
The main reason to run nitrogen in tires is to lower the rolling resistance to impove fuel economy.. it does this by lowering the tire temperature and not allowing the tire to expand as much becuase it runs cooler.... cooler tire = less expansion = less rolling resistance = cooler tires..
post #10 of 77 Old 05-09-2013, 07:20 AM
whans1980's Avatar
It makes sense.
Jeff
I am a heavy rider.. geared up im almost 260... so in short im a fat guy.. lol.. and i run 38 rear and 32 front.. I find this gets me the best traction for my type of riding and doesnt wear the middle of the tire out as much.. I have a friend that has the same bike and he is a light weight rider (only weights about 140) and he runs 42 in the rear and 38 front and he wears the middle of the tire out twice as fast as I do...
Tags
nitrogen, tire pressure
Nitrogen In Tires 09zx10miami Performance and Tech 18 12-30-2010 10:44 AM
Filled with Joy RedHawg Welcome Newbies! 5 11-25-2009 02:44 PM
40 dry shot of nitrious (already filled) 04kawzx-10 Parts, Gear and Accessories 7 06-21-2008 09:23 PM
Nitrogen for your tires.... Fixer The Out House 23 10-22-2007 02:43 AM
Back from Florida, all PM's and orders will be filled Rifleman The Out House 1 04-03-2007 07:59 PM
