Newbie Gen 1 suspension setup - Kawasaki ZX-10R.net
post #1 of 3 Old 06-17-2013, 08:53 AM Thread Starter
Blown Camaro's Avatar
Question Newbie Gen 1 suspension setup
Stock forks/rear shock. Michelin Pilot Pures. Rider 200lbs with gear.
Can you please tell me good STREET suspension setup including sag for my weight? What psi tires? I bought this bike used from someone heavier than me and I know the rear feels very stiff and almost no sag. Front feels somewhat close.
Thank you!
Blown Camaro is offline
post #2 of 3 Old 06-17-2013, 09:43 AM
Does not drive into smoke
El Zilcho's Avatar
Starting sag is usually 30-35mm, both front and rear, then you adjust it to your liking. I have 2CTs and I have 36 PSI in both tires.
El Zilcho is offline
post #3 of 3 Old 06-29-2013, 10:55 AM
You should aim for ~35 mm front rider sag and 25-30mm rear. You the C-spanner to back out the preload on rear shock. If it isn't enough, change the spring. For the compression and rebound settings stick with default settings from owners manual and use it as a baseline.
kiR1ll is offline
Gen 3 zx10r suspension setup Sthlm_74 Suspension and Tire Tech 17 04-18-2015 12:32 PM
Gen 4: Suspension setup with standard springs and shock Quantum Suspension and Tire Tech 38 09-19-2013 12:33 AM
Help! Gen 3 Suspension Setup (220lbs) Looking for the suspension manual chersh1088 Suspension and Tire Tech 17 03-15-2013 07:54 PM
Gen 1: Looking for the best front and rear suspension setup zx10rracer83 The ZX-10R 2 09-21-2012 10:44 PM
Setup Tips for a Newbie to the Strip? jkkustoms Strip 31 09-19-2007 12:47 AM
