michellin pilot power 3 question - Kawasaki ZX-10R.net
post #1 of 2 Old 05-27-2013, 09:20 PM Thread Starter
i just recently fitted in the new pp3 tires on the bike, my last tires that was on it was the stock bt0016 this is on a 08 zx10. on those tires i had the bike leaned almost all the way over to the edge of the tire, they were worn out in the center from the previous owner. after fitting these i have been going alot faster in the same turns, same body position and the wear is shown about 2 inches from the edge, this is a big change, is this new tire offer that much more lean angle vs the bt0016? the pilot power 2ct on my zx6r has been all the way side to side and that was a lot slower speed.
just wondering if anyone else has tryed the new tire and noticed the same thing. this is a great tire tho and very predictable and holds the line perfectly once you turn in.
blackop555 is offline
post #2 of 2 Old 05-28-2013, 04:53 AM
SkyDork's Avatar
The PP tires just have a much different profile. They are typically a bit narrower and rounder than the others which makes it harder to get them scrubbed in to the edges.
#WordCrimes
SkyDork is offline
Thoughts on Pilot Power 2CT front, Pilot Power Road 2 rear? phasterthanyou Performance and Tech 20 11-20-2012 09:47 AM
pilot power question Scott10r Parts, Gear and Accessories 3 09-30-2009 02:45 PM
Michellin Pilot Power andresmejia Parts, Gear and Accessories 0 03-20-2008 12:27 PM
120/60 Pilot Power question PatrickG Performance and Tech 2 04-04-2007 06:14 PM
Pilot Power/Set-up question... El Diablo Performance and Tech 52 11-25-2005 10:40 PM
