Looking for ideas re headshake please - Kawasaki ZX-10R.net
post #1 of 11 Old 11-22-2015, 03:41 AM Thread Starter
greenman43's Avatar
Images: 33
Hi all,
Having a bit of fun with my 10 at Phillip Island last week, and finally decided to try and tame the handling a little.
At the moment, when I change up gears down the main straight at full noise, it does a little headshake each time. I haven't consciously changed geometry (although the ex-BSB frame is new so possibly running a little more rear ride height. Pretty sure it was doing it before the frame change.
I have a set of adjustable offset triple clamps, and was thinking about swapping over the offsets to get some more trail. Does anyone have any other thoughts as to why it might be doing this ?
Suspect this is geometry rather than suspension setup.
Thanks,
Brian
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is offline
post #2 of 11 Old 11-22-2015, 09:03 AM
TechX's Avatar
I don't know if anyone here is running a BSB frame which I'm sure is vastly different from a stock frame. Have you checked the British forums for info from someone using that frame. The stock Gen 4 needs some more rear ride height it doesn't headshake but tends to run wide on corner exit. Other than that the stock dampner needs a rebuild to work properly. Perhaps turn the dampner stiffer a bit may do the trick or have it rebuilt if you haven't done that yet.
TechX is offline
post #3 of 11 Old 11-28-2015, 08:40 PM Thread Starter
greenman43's Avatar
Images: 33
Thanks mate, fairly sure geometry is mostly the same (although linkage pivot point has been moved). Have done some work on the steering damper myself, soldered up the hole in the needle and turned / cleaned it on the lathe. Think I'll be trying the offsets first and see what happens; pain in the bum pulling the front end off, but I have the parts so at least no cost to it !
Cheers,
Brian
post #4 of 11 Old 11-29-2015, 09:34 AM
TechX's Avatar
Cheers,
Brian
Trying the offsets first sounds like the best Idea. Hopefully that will solve the problem. Yes its a pain to pull the front end apart but the results will probably be worth the effort.
TechX is offline
post #5 of 11 Old 11-29-2015, 05:08 PM
I'd highly recommend that you put a Scotts (in Europe called Ohlins rotary) Stabilizer Damper on that bike Right Now.
louemc is offline
post #6 of 11 Old 11-29-2015, 05:57 PM
White Fang's Avatar
A slight headshake when accelerating is normal. I just watched a video I took of a session at a recent track day, I didn't even realize my track bike (GSX-R 750 L2) had been doing a little mild headshake when exiting turns under power. Camera shows it but never noticed it whilst riding. Gen 4 does it too.
Now if it is just plain ornery and unstable, that's a different story, you aren't giving a lot to go on.
But obviously if something has changed and the bike is scaring you, need to figure out why.
I have gotten that same bike to get really out of shape before, incipient tankslapper territory, being too crazy on the gas, power wheelies in 1st/2nd gear it will misbehave, but that was sloppy riding.
Cannot really diagnose or cure on the Internet, ride carefully until you sort it, then continue to ride carefully as no bike is "tankslapper-proof."
Sturm und Drang
White Fang is offline
post #7 of 11 Old 11-29-2015, 06:06 PM
White Fang's Avatar
Better put something on it, need some kind of good damper for sure. I just don't hold with radical solutions right off the bat, tearing the whole front end off and changing up things is not likely to help. Especially since the torque on the steering head has a huge effect on this and that alone might cure it (torque steering bearings). Good luck with it.
Sturm und Drang
post #8 of 11 Old 11-29-2015, 06:12 PM
evallarta1's Avatar
Like White Fang said it's so hard to troubleshoot over the internet, too many variables. But from what you described you could try a turn of preload to see if the rear spring will give you a little more support.
Velocity Calibrations
evallarta1 is offline
post #9 of 11 Old 11-29-2015, 07:03 PM
Mantis_Tech's Avatar
In my experience adding pre load makes the headshake worse. The stiffer rear acts to pogo the rear of the bike under load.
I solved my headshake by taking my bike back to stock geometry (which op can't do)
Mantis_Tech is offline
post #10 of 11 Old 12-22-2015, 02:32 PM
mpp12's Avatar
I lowered the rear and helped inmensly...
mpp12 is offline
headshake 08 10 r bob10r Welcome Newbies! 5 04-07-2014 07:04 PM
How can I minimise headshake? Hattori Hanzo Performance and Tech 26 10-04-2006 12:25 PM
HeadShake or not...? MiamiDave Performance and Tech 19 08-09-2006 12:53 AM
headshake Nick.INF The ZX-10R 23 07-22-2006 02:48 PM
headshake VADER332 ZX-12R Discussion 5 03-17-2006 07:57 PM
