Info on stock suspension Gen 1 - Kawasaki ZX-10R.net
post #1 of 29 Old 05-27-2012, 08:12 AM Thread Starter
OxyG3nE's Avatar
I am riding the stock suspension on the track and kinda getting to the end of its adjustability....
The back is bouncy like hell even after having someone working on the setting half a day.. so i got some advice saying i need to go with a harder spring. The back have never been rebuild and both frond and back are stock..
My question is if its worth it just putting a new spring front and back to my weight or if there is more i can do ? or i should just swap a ohlins (of what ever else) ? Thank you!
OxyG3nE is offline
post #2 of 29 Old 05-27-2012, 10:37 AM
RPG76's Avatar
What do your sag numbers look like? Does the "bouncy" get worse when the shock is hot?
That year ZX10 had pretty stiff springs already, unless your over say 220 ungeared. When people say bouncy it usually means your damping is going.
As for upgrades, how much do you want to spend?
05 ZX10r "the Mongrel": GP Suspension rebuilt forks, LE Penske double shock, 05-06 ZX6rr shock linkage, Brembo RCS MC, Nissin calipers (best mod for this bike!!!), Attack rearsets, Motion Pro Revolver throttle kit, ASV clutch lever, Champs sliders, smoked Zero Grav DB, Ti caliper bolts, CF fender, Renthal grips, Speedo healer, Maviryk MDA123 batt, Supersprox +3 520, That's it..... For now
190/55>190/50
RPG76 is offline
post #3 of 29 Old 05-27-2012, 12:36 PM Thread Starter
OxyG3nE's Avatar
i dont have the number.. i guess i should work my sag myshelf instead of trusting the suspension guy... and yeah i think its worst when its hot.. everyone who saw me saw the back bouncing a lot.. and i know i can feel it ... at first i though its the tire (im running pirelli) but then they said the back is not stiff enough.. with gear im about 190 195..
As for the $$, this is why im looking... is it worth upgrading the stock suspension with part instead of swaping everything? on long terme i mean... i dont want to put 3000 $ but if i end up doing it ... im starting to race this summer...
OxyG3nE is offline
post #4 of 29 Old 05-27-2012, 12:54 PM Thread Starter
OxyG3nE's Avatar
I went on the racetech web site and that is what it gave me :
Recommended Shock Spring Rate: 9.578 kg/mm (use closest available)
Stock Shock Spring Rate: 10.0 kg/mm (stock)
What does it mean exactly?
OxyG3nE is offline
post #5 of 29 Old 05-27-2012, 12:58 PM
Teeks's Avatar
I was running in the top section of intermediate on street tires and stock suspension. I would say if you are planning to do anything more than just the occasional trackday you may want to invest in good suspension, if you really want to get fast. Of course this is just opinion.
I am quite sure if I would ever want to get into advanced type pace, I would be at the limits of the bikes stock suspension. Just like everything else in the world, it just depends on how fast you want to go. Faster = more money lol.
(I am 195-200 in full gear also).
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #6 of 29 Old 05-27-2012, 01:04 PM
4thkawa's Avatar
If u do decide to go aftermarket on the shock. Check Elka out.
http://www.elkasuspension.com/
They are in Boucherville, Que. Pretty close to u.
Don't take life too serious, no one gets out alive.
4thkawa is offline
post #7 of 29 Old 05-27-2012, 01:33 PM
or10r's Avatar
You still got those numbers handy??
or10r is offline
post #8 of 29 Old 05-27-2012, 02:16 PM
Teeks's Avatar
I am not following your train of thought......
Teeks is offline
post #9 of 29 Old 05-27-2012, 03:05 PM
Post Whore
-Op-'s Avatar
I would think he wants to try using your suspension settings and see how they work for him
-Op- is offline
post #10 of 29 Old 05-27-2012, 03:24 PM
or10r's Avatar
Yeah I was just wondering how close my set up is to yours. Im about 205 in full gear. Im ashamed to say I havent set my rear sag and done nothing with my ride height or geometry.
or10r is offline
Need a pro in stock suspension set up Race2 The ZX-10R 12 12-27-2009 12:26 PM
stock suspension... I like saki The ZX-10R 1 04-08-2009 12:36 AM
'08 stock suspension settings.... Older Guy The ZX-10R 1 06-22-2008 08:26 PM
Stock Suspension evallarta1 Performance and Tech 1 07-23-2007 10:12 PM
Suspension Info jessiah1 Performance and Tech 9 03-23-2007 02:26 PM
