Help! My ZX-10R is almost unrideable. - Kawasaki ZX-10R.net
post #1 of 9 Old 06-03-2015, 12:44 PM Thread Starter
Swoop's Avatar
I blew a fork seal a fortnight ago and had a small local shop replace both seals & oil....and the headstock bearings at the same time since it was convenient cos I've done 60,000 miles (C1 model, 04) on her. Since then I've noticed she's really choppy at speed, I mean really really choppy. A smooth road will have the bike getting beaten around all over the place, hit an actual bump and you're airborne.
WTF have they done to my bike and how do I fix it?
Bear in mind I just ride em, I have no idea how they work and me going back to the shop with a "She just doesn't feel right" conversation will result in me feeling like a pillock and nothing being done about it...
Swoop is offline
post #2 of 9 Old 06-03-2015, 01:19 PM
White Fang's Avatar
What they have done is overfilled the oil, most likely. And/or used an incorrect specification of oil. More likely an overfill. That really slams the compression damping all to blazes.
May have overtightened the headstock bearings as well, put it up on stands and do the steering check.
White Fang is offline
post #3 of 9 Old 06-03-2015, 01:21 PM Thread Starter
Swoop's Avatar
Haven't got any stands.....and what's the steering check?
Swoop is offline
post #4 of 9 Old 06-03-2015, 01:29 PM
White Fang's Avatar
Can't do it without stands but you get the front end up and free and turn bars back and forth, check for freedom of movement.
post #5 of 9 Old 06-03-2015, 01:33 PM Thread Starter
Swoop's Avatar
Ah right, simple. I'll see what I can do about that.
As for oil, I need some more info before I have the conversation with the mechanic or I'll get palmed off. Anyone know how much oil is supposed to go into the front forks on an '04 ZX-10R....and what weight should have gone in?
Swoop is offline
post #6 of 9 Old 06-03-2015, 03:10 PM
RIKKITIK's Avatar
The book says;
10 weight oil, 576ml dry/empty, 490ml if just changing it.
Oil level should be, (by book the anyway), -91mm, (+/-2mm), from top of tube, fork compressed and spring removed.
RIKKITIK is offline
post #7 of 9 Old 06-03-2015, 03:28 PM
Bottoms-Up's Avatar
Oil sounds like the culprit, but I check and make sure
the forks aren't pinched either.
Bottoms-Up is online now
post #8 of 9 Old 06-03-2015, 05:50 PM Thread Starter
Swoop's Avatar
Thanks lads, I'll let you know the result.
Swoop is offline
post #9 of 9 Old 06-04-2015, 01:21 PM
backfromthestorm's Avatar
This is why I don't trust anyone but me to work on my bikes. I'm a car tech but if I'm feeling lazy or short of time I'll palm that off on someone else but not my bikes.. Ever. Call me paranoid maybe, but I don't care.
backfromthestorm is offline
2011 ZX-10r Vs 2007 ZX-10r and gsxr 1000 garth285 The Out House 237 01-20-2012 04:10 PM
2011 ZX-10r Race's Modded 2009 ZX-10r garth285 Pictures and Videos 9 01-09-2011 12:12 PM
[email protected]@K: Kawasaki ZX-10R.net ZX-10R 10R ZX10r T- Shirt TheDuder The Out House 1 10-05-2005 10:01 PM
Would you want free ZX-10R.net business cards to give to ZX-10R owners you meet? RichTJ99 The ZX-10R 54 02-22-2005 04:46 PM
