Help! Gen 3 Suspension Setup (220lbs) Looking for the suspension manual - Kawasaki ZX-10R.net
post #1 of 18 Old 02-09-2013, 02:35 PM Thread Starter
Searched but can't find anything except for the stock service manual.
I want to setup my gen3 suspension properly for me (220lbs 5'10")
I've heard that at my weight I should probably buy a stiffer spring for the rear and re valve the rear shock to get optimal performance. But I pretty much just want to setup the best I can with the stock spring/shock.
I found these but the links don't work anymore. Any help or the new links to these would be great!! Thanks
Suspension/Misc Section
08 ZX1000E Setup Suspension.pdf(Right Click, Save As)
Gary J's Suspension Seminar.pdf (Right Click, Save As)
chersh1088 is offline
post #2 of 18 Old 02-09-2013, 04:39 PM
tc10's Avatar
absolutely need a stiffer rear spring
tc10 is offline
post #3 of 18 Old 02-09-2013, 05:23 PM
Nutter34's Avatar
The first one is suggseted settings, which can be hit or miss, due to rider weights and preferences. The other links are methods for setting suspension...
http://www.sportrider.com/suspension.../kawasaki.html
http://www.moto-racing.co.uk/Guides/...nsionSetup.htm
http://www.sportrider.com/suspension...n_setup_guide/
http://www.sportrider.com/motorcycle_suspension/
"You are only young once, but you can stay immature indefinitely."
Nutter34 is offline
post #4 of 18 Old 02-09-2013, 05:46 PM
You will pretty much max the suspension preload and reboad settng.
Sent from my SCH-I535 using Motorcycle.com App
yangins is offline
post #5 of 18 Old 02-09-2013, 06:24 PM
vr6
+1 million on changing the rear spring!
Attack could not set up the stock suspension with the stock rear spring OP...
The front end is fine for a 220lbs rider.
Right now your bike turns into a chopper every time you sit on the bike...
Changing rear spring was like adding 20HP to the motor for me... I am that much faster after changing the rear spring (Racetech)!
vr6 is offline
post #6 of 18 Old 02-10-2013, 10:26 AM Thread Starter
thanks, I think I am going to get a racetech spring and take the bike to metric devil moto in Horsham, Pa. to have them setup the suspension for me.
post #7 of 18 Old 02-10-2013, 01:38 PM
vr6
respect for taking care of the suspension before you toss money at go fast parts...
vr6 is offline
post #8 of 18 Old 02-10-2013, 04:20 PM Thread Starter
lol yeah well I have to get the bike re-dynotuned this spring as well, because I gutted the cats, changing to a m4 street slayer pipe, deleted the sai pump/block off plates, and added a k&n filter so gotta get it retuned. Im hoping for high 160's whp. Bike was previously dynotuned and only mods were two brothers slip on and pcIII.
I am due for a new rear tire so I think I am going to be trying out the new michelin power 3's.
post #9 of 18 Old 02-10-2013, 04:35 PM
vr6
Good stuff... Can't go wrong with Michelin. I'm running 2ct's and they are FANTASTIC!
vr6 is offline
post #10 of 18 Old 02-11-2013, 04:02 PM
tc10's Avatar
i weigh about 210 geared up and i went with the racetech 11.6kg/mm (strongest spring) makes the bike ride so much better. much more control of the bike.
tc10 is offline
Gen 4: Suspension setup with standard springs and shock Quantum Suspension and Tire Tech 38 09-19-2013 12:33 AM
Gen 1: Looking for the best front and rear suspension setup zx10rracer83 The ZX-10R 2 09-21-2012 10:44 PM
Gen 4: Suspension Setup Help zdawg123 Performance and Tech 6 04-01-2012 11:34 AM
Gen 1: Suspension setup Palehorse The ZX-10R 28 03-17-2012 07:49 PM
suspension setup Skydemon7 The ZX-10R 9 08-31-2009 03:57 AM
