Has anyone swapped a 2005 swingarm for a 2008 on a 2005 model - Kawasaki ZX-10R.net
post #1 of 9 Old 08-16-2012, 06:59 AM Thread Starter
GRNINJA's Avatar
I bought a bike with this already done and its been a while since I road my old one, from what I remember it does feel different but there are to many variables changed between the 2 bikes for me to tell.
I would like to know if it made any differences to the handling from what you had before to what you changed to
my old bike had full ohlins
46prxls shock with 20mm internals on the front forks drops 10mm rear ride height stock
fork
rebound 8
comp 10
Shock
low speed comp 12
high speed comp 32
rebound 15
what I have now is , standard forks and standard rear shock but what looks like a WP spring softer than original
.... the bike feels rock and the rebound over bumps is hideous ... I am going to see Mark at MH Racing to get it setup again in a couple of weeks , but just want to know if anyone else has any experience with the change
Ride it like you stole it or at least try.
GRNINJA is offline
post #2 of 9 Old 08-16-2012, 10:17 AM
MUSHU's Avatar
I found this using the search button. https://www.zx-10r.net/forum/showthre...=swingarm+swap
MUSHU is offline
post #3 of 9 Old 08-16-2012, 10:28 AM Thread Starter
GRNINJA's Avatar
I have found a couple of thread on here, but the general consensus was
it hasn't changed much.... I find that hard to believe because the way in which the swing arm is curves changes the way in which it compresses
now because the forks were developed a certain way to work with the way in which the 05 swing ar compresses they won't really work that well together ... i would like to know now if anybody has anymore to say rather than not much difference ... this will be push to the limit and I would rather not bin the bike on track so if i could save myself the aggro now my having good info I will just source an 05 swingarm and be done with it
GRNINJA is offline
post #4 of 9 Old 08-16-2012, 10:42 AM
Squid wannabe
rafa's Avatar
Here
http://www.ebay.com/itm/04-05-KAWASA...ht_2201wt_1182
40 bucks
I had my bike on the track with the 3rd gen swingarm and it was just fine.
I am not all that fast though
"The ZX-10R is capable of being perfectly docile and tractable, but few men are capable of resisting its ever-present voice urging them to just twist it and see what happens."
rafa is offline
post #5 of 9 Old 08-16-2012, 10:45 AM Thread Starter
GRNINJA's Avatar
Originally Posted by rafa View Post
Here
40 bucks
cheers fella ... wrong country though
GRNINJA is offline
post #6 of 9 Old 08-16-2012, 12:51 PM
PatrickG's Avatar
Images: 15
No it's in the right country, you're in the wrong country.. LOL Ur Avatar doesn't say which country your in.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #7 of 9 Old 08-16-2012, 01:52 PM
RPG76's Avatar
What linkage is on it, 1 or 3rd?
05 ZX10r "the Mongrel": GP Suspension rebuilt forks, LE Penske double shock, 05-06 ZX6rr shock linkage, Brembo RCS MC, Nissin calipers (best mod for this bike!!!), Attack rearsets, Motion Pro Revolver throttle kit, ASV clutch lever, Champs sliders, smoked Zero Grav DB, Ti caliper bolts, CF fender, Renthal grips, Speedo healer, Maviryk MDA123 batt, Supersprox +3 520, That's it..... For now
190/55>190/50
RPG76 is offline
post #8 of 9 Old 08-17-2012, 03:08 PM Thread Starter
GRNINJA's Avatar
still on the first gen link , I am thinking of getting an 05 636 on the suggestion from a guy on here with a very trick orange zx10r (not sure he still has it)
GRNINJA is offline
post #9 of 9 Old 08-17-2012, 04:05 PM
All show and all go 10r
JLG0987's Avatar
Rspec I'm assuming? Your biggest difference is stock vs aftermarket suspension.
JLG0987 is offline
Will 2008 bearing housing fit 2005 Supmario89 The ZX-10R 0 07-13-2012 03:46 PM
2005 Nissan 350Z - Black - 6sp - base model abbott Garage Sale 18 02-18-2011 10:57 AM
can you put an aftermarket exhaust for a 2008 on a 2005? wicked The ZX-10R 15 03-08-2009 04:11 PM
Anyone here swapped a swingarm? Top Shelf The ZX-10R 1 10-25-2004 01:58 PM
2005 model greenninja The ZX-10R 14 09-03-2004 07:56 PM
