Going from 190/50 tire to 180/55..how much gear to add?? - Kawasaki ZX-10R.net
post #1 of 31 Old 07-03-2012, 06:55 PM Thread Starter
ke2012's Avatar
Going from 190 tire to 180..how much gear to add??
Hello all,
switching from a 190 50 P1 to a 180 55 P1. I was happy with my gear and i know with making this move the 180 tire is actually taller. How many teeth do i need to add to the rear to get back where i was with the 190?? Ive read 2-3 will get you close...sound right?? thanks in advance. fyi they are mounted on a set of pvm 10y's rear is 6" i believe
ke2012 is offline
post #2 of 31 Old 07-03-2012, 07:32 PM
4sale2's Avatar
why in the world would you use a 180?
4sale2 is offline
post #3 of 31 Old 07-03-2012, 07:36 PM
Shorty's Performance
madnessracing's Avatar
The 180 has a lot less contact patch than the 190 and you will have traction issues unless you're over 200lbs
madnessracing is offline
post #4 of 31 Old 07-03-2012, 07:46 PM
Post Whore
-Op-'s Avatar
if you got a 180/50 it would be a different story somewhat. I would stay with the 190. and the height difference will probably be about 1 tooth, 2 tops.
-Op- is offline
post #5 of 31 Old 07-03-2012, 07:52 PM
SkyDork's Avatar
Well, I'm not a drag guy, so I don't know how this would apply, but....
The 180 is designed for a 5.5" rim, so sticking it on a 6" rim would flatten the profile out quite a bit and increase the contact patch from its original design. So I'm not sure if traction would be affected all that much. But the 180 tire will be lighter weight, so it should help spin up faster than the heavier 190. In practice, I'm not sure how it would get you down the track, but I do see why someone would want to try it. As Op said, the height difference should work out to about adding a tooth on the rear, if at all.
Www.gearingcommander.com should get you closer to what you need to know.
#WordCrimes
SkyDork is offline
post #6 of 31 Old 07-03-2012, 07:56 PM
Teeks's Avatar
Using Skydorks train of thought though, being that it is going on a 6" rim instead of the designed 5.5, seems to me that although normally taller, being spread out wider may make it close to the same height as the 190/50.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #7 of 31 Old 07-03-2012, 09:07 PM
Gen2 Ripper
neverendingmods's Avatar
No, spreading the smaller tire to fit s wider rim shortens it.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #8 of 31 Old 07-04-2012, 07:48 AM
mrbzx7's Avatar
Also remember the sidewall height is a percentage, 180 /55= your sidewall is 55% of 180mm. So I get 99 mm for the 180 and 90 mm for the 190, imo I think the 180/55 would still be taller on the rim. Now I was always told the reason for going to a 180 was for weight mostly. I also can not see how a 180 could have a lot less contact patch when at 15 to 18 psi, it not like we're using the whole tire anyway. So can you elaborate Madness?
BTW I'd say a tooth or 2
Andrews Motorsports
2009 ZX10R aka "The General"
2008 ZX14R coming soon!
Paypal [email protected]
mrbzx7 is offline
post #9 of 31 Old 07-04-2012, 09:50 AM
zx racer's Avatar
i to did this swap to save on weight... when i was runnin a 190 i was -1 +2 but when i switch to a 180 to get the gearing back like i wanted i went up +2 and it was perfect... so i say +2 should get you back to where you want if you make the switch.
05 ZX-10R SWB.
zx racer is offline
post #10 of 31 Old 07-04-2012, 11:44 AM Thread Starter
ke2012's Avatar
My reasoning, is the 180 will give me a wider contact patch and save some rotational weight. I drag race only the bike will never see the street. Dont think i will have traction issues with a p1. Its fairly common, in drag racing to make this move. If it is i have a 190 p1, on the street bike that i can swap out.
ke2012 is offline
Gen 4: ZX10R 2nd Gear 210Km/H,3rd Gear 249Km/H CalvinSars Pictures and Videos 0 09-13-2011 09:33 AM
Gen 4: Zx10R 2011 2nd Gear 210Km/H, 3rd Gear 249Km/H CalvinSars Pictures and Videos 0 09-13-2011 01:15 AM
Weather Gear? Icon Patrol Waterproof Gear 5-F Dawg General Motorcycle Discussions 7 11-20-2010 07:35 PM
IDEA about Gear change and Profile tire change Solo-Six Performance and Tech 5 03-26-2010 12:47 PM
New tire for Free from Cycle Gear..Warranty!!! bluedevil General Motorcycle Discussions 4 04-12-2008 06:52 AM
