Gen4 standard rubber. - Kawasaki ZX-10R.net
post #1 of 83 Old 11-05-2012, 08:35 PM Thread Starter
MYZXR's Avatar
The standard rubber on my new gen4 I have been very happy with (bridgestone 016) the rear looks like it still has more life in it but the front is due to be replaced. Do you think it is ok to just replace the front or should I really do both at once. Seems strange to me to wear out a front first even though i have heard the standard front are very soft.
Sent from my iPhone using MO Free
MYZXR is offline
post #2 of 83 Old 11-05-2012, 09:22 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
I mix and match the shit out of my tires because I go through them like underwear. The bike doesn't seem to mind...
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #3 of 83 Old 11-05-2012, 09:28 PM
jowek70's Avatar
If you think the stock rubber is good, you haven't ridden the bike hard.
The stock tires are terrible and I threw em out the first chance I got.
Save your cash and get something that is worth putting on a $14k superbike.
2 birds with 1 stone.
jowek70 is offline
post #4 of 83 Old 11-06-2012, 08:11 AM
SkyDork's Avatar
The BT-016s that come on the bike are not the same as the BT-016s you buy off the rack. They are made to Kawi's specifications and are NOT very good tires.
Also, you can typically get away with just replacing one of the tires at a time as long as you stay in with the same manufacturer and tire type. If completely changing brands (Bridgestone to Dunlop/Pirelli/Mich) or type of tire (sport to sport-touring) then you really should change them both out together. The tires are designed to work in unison to have the same profile and tread pattern. The characteristics can differ greatly and affect the handling. So just be careful if you decide to do this.
I find it very odd that you've worn the front out before the rear. That to me is an indication that you've got something seriously wrong with the bike setup or the way you're riding it. The typical rule of thumb is a 2-for-1 replacement, meaning you go through 2 rear tires for every front tire. You should really look at the chassis setup, air pressure, etc. to determine the problem. Look at the way the tire is wearing out and see if you can determine where the problem is to get it corrected.
#WordCrimes
SkyDork is offline
post #5 of 83 Old 11-06-2012, 01:09 PM Thread Starter
MYZXR's Avatar
Thanks for the reply. I think I'll be replacing both. I found it odd as well that the front is wearing so fast. I've spoken to other riders here in Aus that have said these fronts are very soft and have experienced the same as me. It could be some thing to do with where I ride as there is a lot of fast down hill twistes. I'll fit some new rubber on both ends and see how that goes. Thanks for your input.
Sent from my iPhone using Motorcycle.com Free App
MYZXR is offline
post #6 of 83 Old 11-06-2012, 01:29 PM Thread Starter
MYZXR's Avatar
Also should of mentioned 34f-36r. Tried lots of other combos but this felt the best to me.
MYZXR is offline
post #7 of 83 Old 11-06-2012, 02:27 PM
SkyDork's Avatar
That type of riding would contribute more towards wearing the front out faster for sure. It sounds like your tire pressures aren't the issue as that is pretty much where they should be.
Well, it sounds like you figured out which way you're going to go, so good luck with it! Oh, and putting a set of Dunlop Q2s on there will change your life!
#WordCrimes
SkyDork is offline
post #8 of 83 Old 11-06-2012, 03:04 PM
jowek70's Avatar
I'm picking up my 2nd set this weekend; bout 2.5k out of the set. As mentioned, completely transforms the bike.
jowek70 is offline
post #9 of 83 Old 11-06-2012, 03:22 PM Thread Starter
MYZXR's Avatar
So these Q2s are they way to go. Sounds good. Excuse my lack of knowledge but can you tell me the full name of them as there is so many variations available. Thanks again for all your advice. Much appreciated.
MYZXR is offline
post #10 of 83 Old 11-06-2012, 03:27 PM
ZX-10R enthusiast
Dunlop Qualifier 2
Different strokes for different folks... I'm currently running Q2 front BT016 rear...before that was PR3 rear Q2 front ;) Doesn't bother me
Sent via iPhone
Gen4: Gen3 rims on Gen4, anyone here done it? Joel The ZX-10R 11 06-04-2015 12:57 PM
Gen4: Standard Rear Shock Oil Bounce Suspension and Tire Tech 3 05-01-2012 02:20 PM
lap timer standard or GPS? zx11dude Track 4 02-23-2012 07:22 PM
Gen 4: Standard o2 sensor what to do? Omega2004 Performance and Tech 1 05-25-2011 06:28 PM
standard gearing? zxrjohn14 The ZX-10R 1 09-20-2008 10:48 AM
