Gen2: Ride Height - Kawasaki ZX-10R.net
post #1 of 6 Old 09-18-2013, 12:19 AM Thread Starter
Gen2: Ride Height
I am 5' 8", and feel that the zx10 2006 seat is low. i used to ride a r6 which was higher. can anyone advice?
also are the stock seats hard or soft?
foursix is offline
post #2 of 6 Old 09-18-2013, 07:00 AM
SkyDork's Avatar
You can raise the rear ride height bu shimming the rear shock at the mount. Washers, a jam nut, the Kawi OEM racing shim stack, etc can all be used. A little goes a long way in terms of millimeters of shim used. 3-4mm would be the starting point as your handling will be affected by this change.
Using my durometer, the shore hardness of the stock seat measures 57.36.
#WordCrimes
SkyDork is offline
post #3 of 6 Old 09-18-2013, 07:21 AM
BusaCaptain's Avatar
The ride height is about the same. The issue is the width of the seat and frame comparing the 2. You have to spread your legs a bit more for the R6 than the ZX which makes the R6 seem taller.
2008 Hayabusa-Yosh Full Race Exhaust can cut 5", PCV w/Autotune, BMC Filter, Cruise Control, HID's. Last Dyno Run 183 Rwhp/107 Ftlbs at 48,954 miles
2006 ZX10R-Street/Track bike- Only mods -1 Front Sprocket, Exhaust Baffle Kit.
2015 R1 (not stock) Imagine that
BusaCaptain is offline
post #4 of 6 Old 09-18-2013, 08:01 PM Thread Starter
on the stock r6, it was low. when fitted with penske, it became higher, and had to tip toe, but corners on track were alot better.
on the zx10, the rear seems low, as i have to bend my knees. i read about the shims. and some forumers mentioned somewhere using up to 10mm. i did this with my rvf,and it raised the tail height about 30mm.
so the stock collar in the shock still to be used?
foursix is offline
post #5 of 6 Old 09-18-2013, 08:07 PM
BigCat for Prez!
BigCat10R's Avatar
Its funny my 06 seems low and I have it sitting stock height but every other bike I've sat on felt tall as shit
Sent from Motorcycle.com App
BigCat10R is offline
post #6 of 6 Old 09-21-2013, 11:37 PM Thread Starter
l am installing a ohIins rear.
will-install the stock collar with 10mm of shim.
Will update results
foursix is offline
Gen 1: Ride height Ulf The ZX-10R 0 02-24-2011 05:19 PM
04-05 ride height question rabbit The ZX-10R 1 08-20-2008 11:35 AM
Ride height Mellonhead The ZX-10R 7 06-13-2007 02:42 PM
ride height CFH Performance and Tech 5 02-08-2007 02:11 PM
Ride height chicken ZX-6R & ZX-6RR Archives 10 08-20-2005 11:51 PM
