Gen1: rebound / compression - Kawasaki ZX-10R.net
post #1 of 4 Old 04-13-2015, 02:25 AM Thread Starter
I noticed more so when going round a fast sweeping bend, the front feels every bump and feels like its jumping up/down quickly or I am fighting to hold on. Perhaps skipping is the word. Now the front has stiff suspension (OEM) anyway.
Do you think I need to adjust my rebound or compression. Settings are :
Front rebound = 9 clicks from clockwise full in
Front compression = 7 clicks from clockwise full in
millsy is offline
post #2 of 4 Old 04-13-2015, 09:01 AM
dricked's Avatar
Sounds like you need to slow the rebound down to relieve the bouncing effect. If it then still feels very harsh over the bumps in the road soften the compression.
dricked is offline
post #3 of 4 Old 04-13-2015, 09:51 AM Thread Starter
Thanks, I will give that a go
millsy is offline
post #4 of 4 Old 04-13-2015, 10:18 AM
White Fang's Avatar
Start at the beginning. What are your spring rates? How much do you weigh? First thing you need to do is get your spring rate right, which may mean new springs (not too expensive). Then get your sag and baseline suspension settings done. Then go ride again and see how it feels and make adjustments from there.
I also recommend you check and adjust your steering head bearings as even a slight looseness can create all kinds of handling problems.
No way you can tell whether it's spring rate, rebound, compression or whatnot from your post. You have to start from the baseline and then make changes after it's set up right.
Also the rear figures into it big time. So do the rear too. Then go out and start fine-tuning.
White Fang is offline
Gen1 Need help with rebound damping adjuster. horsePOOGAS Suspension and Tire Tech 8 03-30-2014 06:33 AM
Istalling Race tech Gold compression and rebound valves flthy1 Performance and Tech 5 05-01-2011 01:22 PM
rebound queston wwarffemius The ZX-10R 20 05-04-2010 07:56 PM
Rear rebound and compression ?.... ZX10Rice The ZX-10R 1 10-13-2009 10:29 AM
Rebound question........ coastiepete Performance and Tech 7 07-21-2008 02:03 PM
