Gen1 rear shock replacement - Kawasaki ZX-10R.net
post #1 of 7 Old 03-31-2015, 05:54 AM Thread Starter
Can someone recommend a replacement rear shock for the Gen1 please. Something that doesn't cost an arm and a leg!!
millsy is offline
post #2 of 7 Old 03-31-2015, 10:17 AM
TechX's Avatar
Why not respring and revalve the stock shock. Thats what I did. It works much better now and was a lot cheaper than an Ohlins or Penske. If your racing you might want the extra performance the Ohlins and Penske or any of the others offer. For streeting riding or trackday i found the revalved stock shock works just fine.
TechX is offline
post #3 of 7 Old 03-31-2015, 05:20 PM
evallarta1's Avatar
What's your budget?
Velocity Calibrations
evallarta1 is offline
post #4 of 7 Old 04-01-2015, 04:44 AM Thread Starter
I am in UK so prices different (properly more expensive!!)
Re-spring and re-valve the stock shock might be an option.
millsy is offline
post #5 of 7 Old 04-01-2015, 08:36 AM
Wiz
Wiz's Avatar
Images: 19
Send a message via MSN to Wiz
Check out the guys at Racelab down on the south coast near Bournemouth , or you could get it re-valved and spring weight changed by any reputable suspension company over here in the UK. I have used Racelab , K-Tech did the work on my gen 1 shock until I change it out for a WP unit . Hope this helps as the companies didn't charge the earth for the work carried out.
Everbody Dies But Not Everyone Lives
Satin Black 05 .... plus lots of mods
Member of the Elite - Growler Group
Wiz is offline
post #6 of 7 Old 04-01-2015, 12:52 PM Thread Starter
Okay thanks. Did you notice a big difference when switching to WP from stock?
millsy is offline
post #7 of 7 Old 04-03-2015, 05:19 PM
Wiz
Wiz's Avatar
Images: 19
Yeah a massive difference , was like a new bike, as everything was dialled in correctly. Well worth the purchase
Wiz is offline
Gen1 Rear shock help toedragger24 Suspension and Tire Tech 1 04-02-2013 01:29 PM
gen1 plastics/front brakes/gen1 hayabusa shock/rearsets/and gear BUGSY_MONTANA410 Parts, Gear and Accessories 8 04-01-2013 02:39 PM
GEN1: Ram Air Tube,Speedo and Rear Shock getzdown540 Parts, Gear and Accessories 1 10-15-2012 07:25 AM
Gen 4: Shock Spring Rate/ Replacement bikefanatic Performance and Tech 3 05-03-2011 05:13 PM
zx10r gen1 (04) clocks replacement m6rk Performance and Tech 4 11-02-2009 08:44 AM
