Gen1 Front Fork Rebuild/General Suspension Improvements? - Kawasaki ZX-10R.net
post #1 of 5 Old 07-09-2012, 04:56 PM Thread Starter
thegoodshot's Avatar
Hey all,
Baseline info: I'm a suspension novice. Bike is stock suspension geometry. I'm 6'2", 180~185lbs no gear. I also very much love the twisties rather than straight-line speed.
My fork seals need replaced on my Gen 1 due to the leakage that seems so common. While they're off I was thinking of having them re-valved and set up for street cornering or a potential track day.
I can either take them to my local shop and have a standard rebuild done, or send them out to a specialist if the price won't kill me. The problem is that I wouldn't know where to begin if I wanted to send them out or make any upgrades. If anyone can suggest reputable suspension fitters I'd appreciate it very much.
Also, the rear tire needs to come off due to a small puncture, so while that is off, is there anything I should do with the OEM shock to enhance handling characteristics?
I've never been really satisfied with the way my bike has felt in corners (twitchy, not confidence inspiring), or overall ride quality (VERY stiff compared to just about every other bike I've been on). So if experienced suspensioneers would like to help out a rookie like myself and provide 101 level knowledge to making a Gen1 handle better, I'd be very thankful!
thegoodshot is offline
post #2 of 5 Old 07-09-2012, 07:02 PM
RPG76's Avatar
GP http://www.gpsuspension.com/ rebuilt my forks, very happy with the work. On my bike I run the forks about 4mm up in the triples. I shimmed the rear 3mm on the stock linkage (2 would have prolly been better) and run 190/55 tires. Speeds up the handling without making it super twitchy.
You might be a little light for the stock springs.
05 ZX10r "the Mongrel": GP Suspension rebuilt forks, LE Penske double shock, 05-06 ZX6rr shock linkage, Brembo RCS MC, Nissin calipers (best mod for this bike!!!), Attack rearsets, Motion Pro Revolver throttle kit, ASV clutch lever, Champs sliders, smoked Zero Grav DB, Ti caliper bolts, CF fender, Renthal grips, Speedo healer, Maviryk MDA123 batt, Supersprox +3 520, That's it..... For now
190/55>190/50
RPG76 is offline
post #3 of 5 Old 07-13-2012, 04:29 AM
or10r's Avatar
I would say look really well for someone you can trust and use them only. If you go from person to person you may end up mixed up. If your not happy after using your first guy THEN move on to another but dont bounce around. Get what you can reasonably afford done (I.E. springs, re-valving ect.) but especially service work. Fresh oil, leak free seals and good wipers. Call around to the guys at Traxxion, Ohlins, GP, AMD Computrac, most of them are more than willing to talk to you about what their options for your bike are and give you a line by line price on what they charge. Dont be afraid to adjust it yourself but KEEP NOTES. Thats HUGE. Keep yourself a detailed journal of what the bike feels like and what it is doing so you dont get lost in adjustment. Good luck to you. Its not vodoo magic it just takes some work to figure out.
or10r is offline
post #4 of 5 Old 07-22-2012, 11:49 PM
slinkt's Avatar
Send them to penske in PA. I did the same thing based on recommendation from gmd computrack when my fork seals failed.
slinkt is offline
post #5 of 5 Old 08-09-2012, 09:06 AM
RdiggA's Avatar
Send you forks here. http://www.metricdevilmoto.com/ Mike did mine on my 06 and they are AWESOME.
RdiggA is offline
Gen1 PC3, Gen2 Front fork, Alpinestars track pants adub Parts, Gear and Accessories 19 01-25-2012 05:54 PM
Gen 1: F.S. Gen1 and Gen 3 Race Tech front fork springs .95 rate PatrickG Parts, Gear and Accessories 10 02-25-2011 03:42 PM
Fork rebuild issues, suspension guru's HELP!! flthy1 Performance and Tech 20 07-21-2010 01:52 AM
Front fork travel distance and suspension issues at philip island csgup1 Performance and Tech 8 04-09-2010 10:55 AM
General suspension setup? ridemyrice Performance and Tech 2 08-24-2006 03:16 PM
