Gen 4: Tyre wear advice Q2s - Kawasaki ZX-10R.net
post #1 of 17 Old 03-05-2013, 05:12 AM Thread Starter
Images: 34
Hello everyone.
I'm hoping someone might be able to give me a bit of advice regarding the tyre wear on my 2011 Gen 4 and whether the wear pattern is saying something about the bike setup and potential improvements I could make.
I currently have on the bike the Q2's and they have 2000km's on both the front and the rear (1240miles) and they seem shagged. After my latest ride there appears to be chunks coming out of my rear tyre and what I think is blistering on my front. I've never had blistering before and I'm worried about what I'm doing to cause it. Photos below btw I used a torch to highlight the wear.
I have had my stock sag set by a local suspension specialist (he was grumpy and didnt tell me the sag settings but he is a well known guy in Canberra and known to be good) and I run the tyres 36 rear 32 front. I am currently 87kg (190lbs) with gear.
Other riders I have asked seem to get significantly more milage out of the Q2's tyres (though on different bikes). I run the bike on full power with traction control mode 2.
Anyone in a similar situation? any hints about what the wear is saying?
Any help would be appreciated.
Cheers
gl8cier is offline
post #2 of 17 Old 03-05-2013, 08:30 AM
SkyDork's Avatar
Well, I'm no expert, but those look bad. Diagnosing tire issues is an art for sure.
The front is tearing something awful. With that pressure in the front, it may be allowing the front to build too much heat and you're hot tearing the rubber apart. First thing I would do is increase the front pressure slightly (try ~2psi cold to start). Increasing the pressure will help stiffen the carcass and not build up so much heat in it from flexing.
The rear to me looks like it's been ridden hard, but not really abnormal. Those "chunked" areas are just what's left of the tread blocks on the sides.
Q2's are not a good tire for mileage at all, but the fact that you're still riding on tires in that condition is a testament to their traction level. Those tires are definitely shot and I certainly wouldn't be running on that front tire any longer in that condition.
Here's some more info if you're interested.
http://2wheeltuesday.com/2009/06/diy...ur-motorcycle/
#WordCrimes
SkyDork is offline
post #3 of 17 Old 03-05-2013, 04:06 PM Thread Starter
Images: 34
cheers for the link!. Some good info there.
Those chunks are actually in a different location than the original side tread grooves. Thats why I was concerned.
I know tyre reading is definatley an art form I wish I had more experience with it.
Thanks
gl8cier is offline
post #4 of 17 Old 03-05-2013, 04:29 PM
nakedinseattle's Avatar
how old are those tires...4 digit date stamp is on the side. i've ridden thousands of miles on q2's and never seen that happen. it does with old tires, or ones with had a lot of temp changes or are stored improperly or
nakedinseattle is offline
post #5 of 17 Old 03-05-2013, 04:38 PM
Rooter's Avatar
Wouldn't be to concerned with the rear as mine looks the same and I've got an ohlins rear shock I run tc1 and full power mode... I usually only get around 2000 to 2500kms out of a rear Q2 which I still found was better then s20s. :headshake
Rooter is offline
post #6 of 17 Old 03-05-2013, 04:45 PM
i usually get between 6-8000 miles on q2's...not sure how you guys are getting so few...
well, rooter, for you i'd say heat.
post #7 of 17 Old 03-05-2013, 05:21 PM
MYZXR's Avatar
I've just got 2500 k's on my rear Q2 and ready to be replaced.
MYZXR is offline
post #8 of 17 Old 03-05-2013, 05:26 PM
All show and all go 10r
JLG0987's Avatar
Your front tire is way to high. Your rear is just a little high. Dunlops are a hard compound tire and need far less pressure then say michelins or pirellis. Try 32/30 or 30/28. Was that street riding or track?
Also how did the bike handle? Slow, very tippy, front trying to wash out, rear sliding a lot, etc...?
JLG0987 is offline
post #9 of 17 Old 03-05-2013, 05:53 PM
Rooter's Avatar
There's no way I could ever get even half of that... In the club I ride with which all are very experienced riders, most are racers if not ex racers and one Steve Mudford owns a sportsbike suspension store all get around the same best is around 3800km on Q2s.
On Dunlop sportsmart which I don't think you get in the states there getting around 5000km.
Hate to say it but if you're getting 13000kms out of Q2s or any soft tire you're going to slow
Rooter is offline
post #10 of 17 Old 03-05-2013, 06:51 PM
out of a street tire i am, daily commuting and weekend twisty riding. i have a track bike for going fast haha and those do not last very long but even on the track i get q2's to last a good long while
one thing to keep in mind is the heat of aus probably plays hell with the tires as well, don't really have that problem up here
First gen track bike suspension and tyre question csgup1 Performance and Tech 3 11-25-2010 02:58 AM
190/55 tyre on gen 1 Trunks The ZX-10R 14 05-16-2009 11:47 PM
More tire (tyre) pressure advice SoCal90 Performance and Tech 3 11-09-2007 12:02 PM
Stock suspension settings and excessive tyre wear Harlequin The ZX-10R 8 08-11-2007 07:26 PM
Front tyre wear milo5171 The ZX-10R 6 03-19-2007 08:42 AM
