Gen 4: TTX GP adjustment knob mounting locations? - Kawasaki ZX-10R.net
post #1 of 22 Old 09-25-2014, 10:37 AM Thread Starter
STEALTH-FIGHTER's Avatar
Just curious what most have done with the oem And aftermarket subframes. The only place it seems to mount on the oem, without the adjustment cable rubbing on the swing arm, is on the left passenger peg hole. Just looks out of place there to me.
I will have the Motoholders subframe soon, so will have to figure something else out then.
Here's a couple pics,
What is best in life?..
TO CRUSH YOUR ENEMIES, TO SEE THEM DRIVEN BEFORE YOU, AND TO HEAR THE LAMENTATIONS OF THEIR WOMEN.
STEALTH-FIGHTER is offline
post #2 of 22 Old 09-25-2014, 11:22 AM
SkyDork's Avatar
Most of the people I've seen have it mounted in that same general location, but using the forward hole and running the knob back parallel with the tail section as much as possible.
And I would advice NOT running the line through the swingarm opening like that! That's asking for trouble if the swingarm pivots down and rips the line out of the adjuster or limits the downward stroke of the rear suspension. That's not good at all.
#WordCrimes
SkyDork is offline
post #3 of 22 Old 09-25-2014, 11:40 AM Thread Starter
Well the problem lie's with the cable itself and its orientation to the swing arm. If you try to route it over it, it puts strain on the connection at the shock, because the swingarm is pushing on the line about 1.5"-2" away from the shock.
Alberto said he tested the suspension, in its current orientation, to insure that the cable doesn't touch anything when the bike is fully decompressed. When under compression it only gives it more slack.
I've tried routing it different ways too since I've had it back, and this seems to be the only way it doesn't make contact.
I originally figured the adjuster would be in line with the tail as well, though noticed that the nuts that hold the adjustment knob to the bracket are in the way of the subframe. This could of course be solved by spacing the bracket about 3/8" away from it, though when the knob is at that angle, the cable makes contact again.
post #4 of 22 Old 09-25-2014, 12:01 PM Thread Starter
Anyone with the TTX GP on the gen 4 please post photo's of your set up.
post #5 of 22 Old 09-25-2014, 12:09 PM
I've got mine mounted the same way except the hydraulic cable goes over the swing arm. This way looks fine to me too.
On a side note:
If anyone is using the forward mounting hole for your preload adjuster, make sure the bolt is not too long. I had mine previously mounted there, had a minor lowside, and it put a hole into the gas tank.
NeedSpeed is offline
post #6 of 22 Old 09-25-2014, 12:20 PM
SkyDork's Avatar
Can you mount it on the right side of the bike instead?
#WordCrimes
SkyDork is offline
post #7 of 22 Old 09-25-2014, 12:34 PM Thread Starter
Was thinking about trying that. Might do it in a bit. There would be more slack on the line, due to the offset shock. It's just a pain in the dick to get the adjuster through the swing arm without putting too much stress on the connections, or marking up the adjuster, and there's even less room on that side to navigate.
post #8 of 22 Old 09-25-2014, 12:44 PM Thread Starter
I'm really mostly interested in set ups on the Motoholder's subframe. I 'think' the only solution for mounting the bracket is on the right side anyway, through the provided exhaust hanger bracket holes.
Just hoping someone doesn't say I have to use zip tie's
post #9 of 22 Old 09-25-2014, 12:50 PM
dricked's Avatar
Kind of a crappy pic but as you can see the cable is over the swingarm. I used a piece of clear tubing, cut it down the middle and zip tied it over the adjuster hose. After 6 race weekends there's very little wear on the outside hose and none on the swingarm. I'll take a better pic tonight.
I wouldn't route it through the swingarm for the same reason sky said.
I have a motoholders subframe now and drilled a hole into the plastic under tray for the bolt. I'll have a pic in a couple hrs for you.
dricked is offline
post #10 of 22 Old 09-25-2014, 12:57 PM Thread Starter
Thanks Dricked, I may have to use your method with the clear hose over the line, however the big difference is that your connection go's straight into the adjuster instead of at a 90 degree angle like mine. I may still be able to make it work like that, if it's over the swing arm, but I'm going to have figure something out with the bracket to make it work, or fab a new one.
What shock is that btw?
Gen 3 Ohlins TTX Shock gobigbakes Parts, Gear and Accessories 0 09-25-2013 09:25 PM
Gen 2: Ohlins TTX KA 606 shock oldkamikaze Parts, Gear and Accessories 7 05-01-2011 06:16 PM
GEN 3: WTB Ohlins TTX Strik33r Wanted: Buy or Trade 0 02-19-2011 01:20 PM
Ohlins TTX Shock Adjustment GrtSaint72 Performance and Tech 3 02-18-2010 12:37 AM
VholdR 10r mounting locations? vagrant The ZX-10R 9 07-17-2009 09:34 AM
