Gen 4: Front end loosness/clunk? - Kawasaki ZX-10R.net
 1Likes
post #1 of 14 Old 05-16-2016, 10:03 AM Thread Starter
Victors's Avatar
Little back story on the bike.
2013 10r... Bought it from an idiot last fall. Didnt get to ride it cept the test ride until this spring. Over the winter I changed the clipons and did all the maintenance the previous owner didnt do. Got the bike out recently and the front end would rattle/clunk on bumps and was very bad when braking on other than a smooth surface. Immediately turned around and realized i had the clipons a tad high which kept the triple from completely seating. Did some adjustments and reset the upper triple and torqued the nut.
Long story short, the issue is still there. Double and triple checked to make sure the upper triple is correct and it is. A google search suggests its the steering head bearing, forks bottoming out internally.. etc
Ive checked for a loose bearing and seems fine... any ideas?
Thanks guys
2013 10R
2007 650R
2016 10R
Victors is offline
post #2 of 14 Old 05-16-2016, 10:24 AM
SkyDork's Avatar
How did you check the head bearings? That's usually what the issue is. You have to remove the upper triple and the lock collar. Then you need to get on the actual nut with a spanner wrench. There's no torque spec on it. It's a functional check to get rid of the clicking and making sure the steering isn't too tight.
#WordCrimes
SkyDork is offline
post #3 of 14 Old 05-16-2016, 10:35 AM
dhorcher's Avatar
I agree with Sky. Sounds like head bearings. I had a similar sound when coming to a stop but I also would get head shake over uneven surfaces, I took it to my local dealer had them check the bearings. Guy said they were so lose that after removing the jam nut he tightened them down by hand before torqueing them. My bike is a 2015 with only 1k and I knew they would need checked with a service. Point is that if the PO didn't have services or maintenance done then they def need checked.
dhorcher is offline
post #4 of 14 Old 05-16-2016, 01:54 PM Thread Starter
Victors's Avatar
No movement when bike is up and I'm pulling and pushing on the front wheel. I'm pretty familiar on what it feels like if it's loose. I suppose it's possible I'm just not getting the right angle and whatever to get the movement to show. I'll go ahead and dig of a spanner wrench and start playing. Really don't wanna do a bearing if I don't have to lol. Though I'm starting to feel like it's a pretty good possibility.
Thanks guys.
2013 10R
2007 650R
2016 10R
Victors is offline
post #5 of 14 Old 05-21-2016, 01:52 AM
Mine was making a sound like this. It was the steering damper. They slap around quite bad. All i did was remove center bolt and fit a thin rubber washer underneath. Now steering damper silent.
ukzx10r is offline
post #6 of 14 Old 05-22-2016, 10:52 PM Thread Starter
Victors's Avatar
Figured I'd give ya an update...
All fixed, at least so far it is. Pulled the triple off and grabbed the ole spanner and tightened the nut up a tad.. assuming that it was either loose from the factory or it loosened up because the upper triple wasn't snug. Either way, it's all good. Thanks guys.
2013 10R
2007 650R
2016 10R
Victors is offline
post #7 of 14 Old 06-03-2016, 12:27 PM
pkendall's Avatar
Reading this thread and although not directly this issue, any thoughts on this clicking? Thanks in advance!
https://1drv.ms/v/s!AsNfF-86osjYsTdobg8pp_Plczyi
pkendall is offline
post #8 of 14 Old 06-03-2016, 01:16 PM
SkyDork's Avatar
Rotor bolts hitting the front stand.
ukzx10r likes this.
#WordCrimes
SkyDork is offline
post #9 of 14 Old 06-03-2016, 03:21 PM
57x
It is always amazing to me to see a brand new bike not setup correctly. I have seen a few with loose headset bearings. I pulled the upper triple on my Gen5 when I brought it home to confirm, even though the dealer was a friend. All was good. The biggest issue with this now that all bikes come with roller bearings is, all it takes is a couple hard landings from a wheelie and you can dent the race or worse. If not too bad you get some stiffness moving the bars, worse is if the dent is just slightly off-center and you fight to keep a straight line. I just helped a friend put in new races because he didn't have the headset adjusted correctly. He is a hooligan, that only knows how to ride on the back wheel, so this will probably happen again.
57x is offline
post #10 of 14 Old 06-03-2016, 03:44 PM
Definatly that. Mine did it once
ukzx10r is offline
gen 2 front end. Cloud 9 Suspension and Tire Tech 4 06-03-2013 07:29 AM
Gen 4 Front End Vibration Proteus The ZX-10R 32 08-28-2012 08:26 AM
Gen 4: Front End Torque Values Proteus The ZX-10R 12 08-21-2012 10:19 PM
Gen 4: Front End Vibration and Clutch Freeplay Proteus The ZX-10R 10 07-18-2012 02:54 PM
first gen front end install help kuziken10r Performance and Tech 11 08-07-2010 02:54 AM
