Gen.4 Elka rear shock - Kawasaki ZX-10R.net
post #1 of 10 Old 02-01-2014, 12:47 AM Thread Starter
ZX-Trafaz's Avatar
I just got a Elka stage 4 Hydraulic rear shock . Does anybody have advice or pics. Where to mount the two components , pre-load adjuster knob and the hydraulic canister.. Two separate lines..! Thanks guys
ZX-Trafaz is offline
post #2 of 10 Old 02-01-2014, 04:56 PM Thread Starter
ZX-Trafaz's Avatar
Bueller, bueller...
post #3 of 10 Old 02-01-2014, 07:48 PM
C Dub's Avatar
Elka Location
Mounted my reservoir next to the shock location in the swingarm cavity - had to cut down the rubber mounts to allow for 1/4" clearance from the shock. Shock has been on the bike for about 1 year with no issues.
- CW
Name:	Elka Mound.jpg
C Dub is offline
post #4 of 10 Old 02-01-2014, 09:17 PM
badexample's Avatar
Try to make it fits in the wires/battery tray .. Will look the best. I don't think that you need constant adjustments unless you are track junkie.
“Ride like you are invisible.”
badexample is offline
post #5 of 10 Old 02-01-2014, 11:19 PM
Squid wannabe
rafa's Avatar
I cant help with your question.
But if you have the non ABS version, and/or have a Lithium battery, you should have some space under the seat, i would try to get the reservoir in there.
Most people seem to bolt the pre load adjuster to one of the hole for the passenger foot pegs.
Im sure Elka design the shock with the placement for those in mind, you should send them an email.
"The ZX-10R is capable of being perfectly docile and tractable, but few men are capable of resisting its ever-present voice urging them to just twist it and see what happens."
rafa is offline
post #6 of 10 Old 02-02-2014, 02:40 AM
Red_Comet's Avatar
Talking Ha ha ha!
Originally Posted by ZX-Trafaz View Post
Bueller, bueller...
Funny!
I just noticed this thread... On mine I located the hydraulic pre-load adjuster on the left side and the remote reservoir on the back side of the exhaust mount. This allows for easy adjustment of the shock and the high/low speed compression damping on the reservoir. Granted this isn't adjusted often, but its location does make it easy when I do - or more accurately, when my suspension guru does.
Good luck.
ID:	243745   Click image for larger version
ID:	243753   Click image for larger version
ID:	243761   Click image for larger version
Red_Comet is offline
post #7 of 10 Old 02-02-2014, 03:23 AM
I have mine mounted as above, but I hate having it there. If you take a tumble at the track - that reservoir may be toast!! I like the swingarm mounting - I'm going to see if I can do that.
Never pat a burning cat.
melbr1 is offline
post #8 of 10 Old 02-02-2014, 11:30 AM
Red_Comet's Avatar
I agree with you.
I got concerned about the very same thing and for my exhaust as well, so I recently got one of the R&G hexagonal exhaust sliders (amateur photog caught me on a ride last week).
I think it looks OK, but it will definitely help keep both my can and the remote reservoir off the pavement should the unfortunate low-side happen. Of course, if I take a real tumble all bets are off....
Name:	HWY 9_2014-01-27.jpg
post #9 of 10 Old 02-02-2014, 07:12 PM
Wow that is unsightly.
2016 GSX-S1000
08 10r Sold
Walter is offline
post #10 of 10 Old 02-03-2014, 10:22 AM
Post Whore
Older Guy's Avatar
Older Guy is offline
Gen 4: Stage 4 Elka Rear Shock badexample Parts, Gear and Accessories 23 09-20-2013 11:15 PM
Anyone used an Elka rear shock yet? ryanbz2001 Performance and Tech 6 08-10-2007 04:41 PM
*Sold*04-05 Elka Triple (rear shock) kneedragger Parts, Gear and Accessories 4 08-02-2007 01:39 PM
WTB: Used Penske/Ohlins/Elka rear shock Cling Wanted: Buy or Trade 6 04-21-2007 03:14 AM
Elka rear shock. rocketracermike The ZX-10R 1 11-12-2006 01:39 PM
