gen 4 bushing kit - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By Bigunz
post #1 of 7 Old 02-01-2016, 03:43 PM Thread Starter
mpp12's Avatar
gen 4 bushing kit
When a fork is leaking, is necesary to change the dust oils but my question is..
Is it necesary to change the bushing kit also???
All Balls Fork Bushing Kit for Kawasaki ZX10R 2011 2015 | eBay
mpp12 is offline
post #2 of 7 Old 02-01-2016, 04:39 PM
Always On Mod
Animal11's Avatar
once you pull the forks off the bike, disassemble, drain the oil, inspect all the o-rings, you will probably have a couple hours into it. For peace of mind it's probably worth the extra $34 while you're in there. Necessity will be determined by the wear on the existing parts, so you won;t know until you get into it.
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #3 of 7 Old 02-01-2016, 04:56 PM
SpazOnaZX's Avatar
This. If your lower bushings are truly trashed you will notice wear on the inner for tube/slider as well... it will look like lots of parallel vertical scuff marks near the dust seal area. That being said, I haven't had a set of sub-60K mile forks of my own come apart yet with bushing wear that required replacement.... but it does happen. Those little bastards are fun to change, though!
SpazOnaZX is offline
post #4 of 7 Old 02-01-2016, 11:47 PM
Personally.. I would replace the guild and bushings as they need to be smashed into each other to split the tubes and as a result of that it nearly always damages the coating.
Bigunz is offline
post #5 of 7 Old 02-02-2016, 08:58 AM
SpazOnaZX's Avatar
.... you do not have to remove the bushings on our "USD" forks to change oil & dust seals...... if you DO take them out, you might as well replace them at that price; I can agree with that.
post #6 of 7 Old 02-02-2016, 05:23 PM
Well.. I think your referring to other forks.. These are BPF were talking about.
SpazOnaZX likes this.
Bigunz is offline
post #7 of 7 Old 02-03-2016, 08:36 AM
SpazOnaZX's Avatar
Ooooooops, good catch. I read Gen 1.... because I'm an idiot in bursts. :)
Thanks on the correction.
FWIW I've done a lot of old traditional forks where you have to slide hammer the bushings out and I've never used the correct tool to get them back in. I've been fortunate enough to never hurt one, but it is very easy to screw it up without the right tools.... sure wouldn't hurt to have a few spares on hand.
Gen 2: Defective lower fork bushing Gnarwal The ZX-10R 1 05-27-2015 09:50 AM
Oem fork bushing cow10r The ZX-10R 6 11-05-2012 12:35 AM
Gen 3: will a 1st gen lock-up clutch pak kit fit a 3rd gen 08???? ke2012 Performance and Tech 0 01-22-2011 08:36 AM
Will a 2nd gen kit generator fit the 3d gen? Balogiannis Performance and Tech 10 12-19-2010 01:58 AM
gen 2 and gen 1 kit cams lil ninja Performance and Tech 8 12-23-2007 08:59 AM
