Gen 3 zx10r suspension setup - Kawasaki ZX-10R.net
post #1 of 18 Old 05-19-2013, 04:35 PM Thread Starter
Sthlm_74's Avatar
Hi guys! I need some help with front and rear suspension on my bike, I`ve just bought it and itīs a little to soft for me. If some one have like a "start up setting" for trackdays that I can start with? Maybe with just counting the clicks? Everything is oem, and my weight is 85kg.
Cheers!
Sthlm_74 is offline
post #2 of 18 Old 05-19-2013, 05:05 PM
vr6
Your front springs are fine for your weight 187lbs...
Front:rotate rebound and compression full soft then go 3 clicks...
I like 5 1/2 lines showing on tripple tree top of shock... Good starting point...
The rear is so soft that's gonna be on you to see how firm you can set it and get comfortable...
Don't forget to check tire pressure...
I'm 100% street rider so this is what I run for the street...
Good luck and congrats...
vr6 is offline
post #3 of 18 Old 05-19-2013, 07:59 PM
I used this as a base for mine then kinda worked from there. I really liked the setting they had for my 600rr.
http://www.sportrider.com/suspension.../kawasaki.html
drifthunter is offline
post #4 of 18 Old 05-20-2013, 04:02 AM Thread Starter
Sthlm_74's Avatar
Thanks alot! Now it's time to start fuck up things in The garage! Hahaha!
Cheers!
Sthlm_74 is offline
post #5 of 18 Old 05-27-2013, 09:25 PM
with your weight you could do with bumping up the rear spring stiffness, big difference
blackop555 is offline
post #6 of 18 Old 05-29-2013, 08:21 PM
vr6
Agreed!
That was a major improvement on the bike...
(New Rear spring with stock shock)
vr6 is offline
post #7 of 18 Old 06-02-2013, 02:37 PM Thread Starter
Sthlm_74's Avatar
I'll try that aswell! Thanks for helping me out!
Sthlm_74 is offline
post #8 of 18 Old 06-02-2013, 06:41 PM
since I didn't see any info. When you do a rear spring like racetech. Do you need an adapter/spacer for the new spring?
post #9 of 18 Old 06-03-2013, 05:16 AM
There is a collar that comes with spring. If you want the shock back in OEM shock travel then you will have to buy an additional collar/spacer. It's about an inch and a half thick. Don't remember number but you can find it on racetechs website
post #10 of 18 Old 06-03-2013, 09:47 AM
tweak's Avatar
im 88kg without gear stock spring had to go. i had stock shock revalved re oiled new spring 11.2 kg 110 nm had the 1way valve fitted and top out spring removed and no shit it is night n day compared to stock its best money ever spent perfect feel. i recommened it
tweak is offline
Gen 4: Suspension setup with standard springs and shock Quantum Suspension and Tire Tech 38 09-19-2013 12:33 AM
Help! Gen 3 Suspension Setup (220lbs) Looking for the suspension manual chersh1088 Suspension and Tire Tech 17 03-15-2013 07:54 PM
Gen 1: Looking for the best front and rear suspension setup zx10rracer83 The ZX-10R 2 09-21-2012 10:44 PM
ZX10R 09 Suspension Setup? Luiz_Direito The ZX-10R 2 02-23-2010 06:40 PM
ZX10R Suspension setup stanmann The ZX-10R 13 06-30-2004 12:42 AM
