Gen 3 swingarm on a second gen - Kawasaki ZX-10R.net
post #1 of 12 Old 10-09-2012, 07:03 PM Thread Starter
Getting ready to do the swap ..looking for a parts list and a couple of hints ....any help ?
Sent from my Galaxy Nexus using Motorcycle.com App
macgyver1307 is offline
post #2 of 12 Old 10-09-2012, 07:53 PM
MUSHU's Avatar
I used the search button and found this. https://www.zx-10r.net/forum/showthre...hlight=Andicog
MUSHU is offline
post #3 of 12 Old 10-09-2012, 10:35 PM Thread Starter
Yeah thanks I saw that but it doesn't say what shock he used or if he used different linkages... or what the suspension set up ....that's the info I'm seeking ! Thanks for the help!
post #4 of 12 Old 10-17-2012, 09:28 AM
SpOoNpR's Avatar
I changed my Gen1 swing arm to a Gen2 besides the swing arm itself used the stock Gen 1 parts. then i changed the Gen 2 for a Gen 3 and same thing everything match.. i do have the 3 hole bones from the Gen 1 install... dont think that makes to much of a difference tho..
SpOoNpR is offline
post #5 of 12 Old 10-17-2012, 01:13 PM Thread Starter
How was the right height and the suspension set up ...did it improve? Did you look into using 636 linkage ?
post #6 of 12 Old 10-17-2012, 01:32 PM
SpOoNpR's Avatar
i saw a lot of diffrent post here found one that said that everything matched so i gave it a try.. suspencion felt the same and the height was 2 cent above what i had before i adjusted the stock gen 1 shock to match and ta da!
SpOoNpR is offline
post #7 of 12 Old 10-21-2012, 07:24 PM
TinMan_38's Avatar
I used a low mileage gen3 shock, gen2 rocker, and soupy's adjustable links, but the stock gen2 links will work fine. It is truly a by up deal, but you will need the gen3 brake caliper and bracket and a gen3 brake line. Other than that, I can't remember anything else. Oh, you won't be able to run the under tail exhaust after, so a side mount or custom turn down is a must.
Sent from my iPhone using Motorcycle
there are few problems in life that the proper application of throttle will not fix.:deathmeta
TinMan_38 is offline
post #8 of 12 Old 10-22-2012, 05:32 PM
diohji's Avatar
Images: 19
what are the benefits of swapping to a 3rd gen swing arm?
I dont always use emoticons, but when I do, its this
Ride safely my friends
diohji is offline
post #9 of 12 Old 10-22-2012, 06:09 PM
TinMan_38's Avatar
Aesthetics and appearance mainly. Little or no handling advantage. Once you pull the under tail it leaves a very open tail. Now that, in my opinion, looks pretty bitchin, but I wanted a more updated look. It's for personal preference.
post #10 of 12 Old 10-22-2012, 06:25 PM
SpOoNpR's Avatar
Originally Posted by tinman_38 View Post
aesthetics and appearance mainly. Little or no handling advantage. Once you pull the under tail it leaves a very open tail. Now that, in my opinion, looks pretty bitchin, but i wanted a more updated look. It's for personal preference.
Sent from my iphone using motorcycle
SpOoNpR is offline
Gen 1: swingarm extensions and swingarm shadyracin Parts, Gear and Accessories 11 01-02-2013 08:51 AM
2nd Gen Swingarm on a 3rd Gen ZXRANDY Performance and Tech 14 12-24-2010 01:26 PM
Gen 3 swingarm kit edouble Parts, Gear and Accessories 10 10-27-2010 07:02 AM
04/05 10R swingarm trackaddict Parts, Gear and Accessories 0 04-26-2009 09:38 AM
04-05 swingarm sweetride10r Wanted: Buy or Trade 2 05-26-2007 09:13 AM
